Could PCV be my problem...
Old May 2, 2005 | 07:15 AM
JDM_SOHC's Avatar
Default Could PCV be my problem...
Could a bad PCV valve cause my car to have surging idle.... 1100 rpms to 1600 rpms up down up down up down.... I've checked all my sensors on the Intake Manifold and checked all my vacuum lines.. Fuel Pump turns on when key is in On position, and i've never heard of a fuel filter causing this problem....
Old May 2, 2005 | 07:31 AM
flood's Avatar
Default Re: Could PCV be my problem... (JDM_SOHC)
Could be the Idle Air Controller. The PCV shouldn't cause a surging idle. There are threads about cleaning the IAC, just do a search and some shoudl come up.
Just last week there was one with your exact problem. Suggestion to clean IAC worked and he posted a follow up.
Old May 2, 2005 | 07:37 AM
Bcuz's Avatar
If you remove your PCV valve you will get a slight surge or high idle. Just remove your PCV valve and check it out, if it looks clogged replace it and clean the tube and everything related with gum cutter. Good Luck.
Even easier, clamped the hose with some vice grips, if your here a click from the PCV valve it's working correctly.
Old May 3, 2005 | 04:40 AM
JDM_SOHC's Avatar
Default Re: Could PCV be my problem... (Bcuz)
Alright i'm gonna give it a shot today, preciate it...
drock305
Nov 7, 2007 06:56 PM
JBirch_97Prelude
Mar 26, 2007 08:43 AM
95redeg6
Sep 2, 2006 08:07 PM
DubyaAye
Mar 7, 2005 06:33 AM
jeffk182
Jun 24, 2004 10:47 AM
