ROugh idle
ROugh idle
so yesterday i installed my itr manifold with no problem. it starts up fine and idles nice but a soon as it warms up my idle is just up and down. i am thinking it is a vacumn leak but from where everything is hooked up. is there something that i am missing?
thanks for the help
thanks for the help
Re: ROugh idle (95redeg6)
yep coolant bleed still does the same ****. i find it odd that it doesnt do it constantly only when i stop and only for like 10 seconds then it will idle then sometimes it will just do it forever.
shop teacher said to clean my throttle body out and that may cure the problem because there isnt any leaks from my hoses or gaskets and then to adjust my fuel pressure alittle too high
i need to lash my vavles and my buddy said it might help with the idle. is this true?
fluctuating idle is probably gonna be some sort of vacuum leak.
on my d16z6 with skunk2 mani, it goes up and down because the brake booster line doesnt seal correctly.
do you still have the FITV?
i think mayb that it is my iacv......but it was running fine with the b16 mani. could i have damaged it taking it off or something...**** this is begining to really irratate me.....
Eurasia00
04-22-2002 11:37 AM
