What axles are you guys running?
Old May 1, 2005 | 09:26 PM
Rocks
Guest
Posts: n/a
Default What axles are you guys running?
Please state your HP #'s and how long youve been running these axles. Thnx and did you break your stockies and the reason for upgrading.
Modified by Rocks at 11:18 PM 5/1/2005
Old May 1, 2005 | 09:44 PM
s2kdre's Avatar
Default Re: What axles are you guys running? (Rocks)
alot of people run stock axels with 300whp as long as you dont drop it at 8k they wont brake.
Old May 1, 2005 | 09:53 PM
Garcia-Racing's Avatar
DSS stage 5's on 650ish
Old May 1, 2005 | 10:01 PM
vaporboy12's Avatar
Default Re: (Garcia-Racing)
400whp gator stage 2's thanks terry and stan
great axles
Old May 1, 2005 | 11:03 PM
BoostedJeff's Avatar
Default Re: (vaporboy12)
planning for 550whp+ and using Fidanza's
Old May 2, 2005 | 06:33 AM
underpressure02's Avatar
dss stage 4 only 300 hp. Been dropping it at 7k on 24.5 slicks for over a year. No problems.
I got them b/c I did not want to break and axle at the track and hold everyone up or even worse oil down the track. Plus I don't trailer my car so I want to make sure I can drive it home at the end of the day.
Old May 2, 2005 | 06:47 AM
B16Civic93's Avatar
Default Re: What axles are you guys running? (underpressure02)
aren't you guys worried about breaking the differential? or the tranny? i put a hole in my transmission launching it hard . it hoppedreally bad though i had broken motor mounts
Old May 2, 2005 | 07:06 AM
Default Re: What axles are you guys running? (B16Civic93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">aren't you guys worried about breaking the differential? or the tranny? i put a hole in my transmission launching it hard . it hoppedreally bad though i had broken motor mounts</TD></TR></TABLE>
I run a quaife lsd and solid motor mounts with traction bars no wheel hop here. It is smooth as butter when I take off.
Old May 2, 2005 | 09:47 AM
I am running a richmond spool and traction bars.
....I ain't scurreddd
Old May 2, 2005 | 09:49 AM
yellowturbo's Avatar
stock axle on my D16... as long as you dont launch and get wheel hop... in most case OEM axle will be fine.
Old May 2, 2005 | 09:57 AM
rmcdaniels's Avatar
Stock B16 axle -w- 350-408WHP for a year or so. I always slip the clutch on launch.
Old May 2, 2005 | 11:00 AM
anothaRRR's Avatar
Default Re: (rmcdaniels)
560whp on 300m High Performance Gator Axles
Old May 2, 2005 | 11:16 AM
Quad-Damag's Avatar
Default Re: (anothaRRR)
Gator Stage 2 with lsd
one day soon
Flexin5
Sep 15, 2006 03:08 AM
nY's FiNeSt
Dec 8, 2005 03:15 PM
*Boostwerks*
Mar 3, 2003 06:27 PM
Jdm_Rice_Monster
Feb 4, 2003 05:53 AM
MysteriousGSR
Dec 5, 2002 03:37 AM
