idle problem
my 97 dx(stock) has this idle problem were after i start it idles high until warm them starts to idle normal then drop to the point of almost shuting off only to go back then fall again. i had a friend use his code reader and it came up as a bad map sensor i replaced it but the problem is still there, can anybody help me?
Modified by J_Trez at 1:24 PM 4/29/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Reset your ecu, could be your IACV, or you may just need to adjust your idle.</TD></TR></TABLE>
immalooser
Feb 18, 2009 05:23 AM
mikeunreal2
Mar 29, 2006 09:27 PM
