550's work with hondata and 8lbs of boost
Old Apr 28, 2005 | 10:00 PM
Bigplans06's Avatar
Default 550's work with hondata and 8lbs of boost
i was trying to sell my rc 550's and they dont seem to be selling so i was wndering if they will work with hondata,walbro fuel pump and im only going to be running 8lbs, the spring size.its a built h22,9:1 je pistons,if any of this info is nessesary. a shop near me said that it wont perform the duty cycle or something like that, i just wanted some other opinions. still new to turbo setup, thanks guy
Old Apr 28, 2005 | 10:12 PM
turtle-eg's Avatar
Default Re: 550's work with hondata and 8lbs of boost (jdmclick8u)
They will be fine... I had rc550s in my lsvtec and it started, idled, and drove fine, just like stock. Also the 550s should be enough for the 8psi you're planning for.
Old Apr 28, 2005 | 10:19 PM
SFWD 1934's Avatar
Default Re: 550's work with hondata and 8lbs of boost (turtle-eg)
Depending on fuel set up (i.e. pump/regulator/rail psi at idle/etc) those should be good for somewhere in the area of 300whp. That will put you at a decent duty cycle.
Jason
Old Apr 28, 2005 | 10:46 PM
Bigplans06's Avatar
thanks guys for your input, really appriciated
Bictorious
Mar 9, 2004 09:14 AM
hatchback
May 20, 2003 09:00 PM
Anubyss
May 16, 2003 05:12 AM
SweetChin
Mar 31, 2003 02:33 PM
tecnic1
Dec 3, 2002 05:52 PM
