720cc with Hondata
Old May 15, 2003 | 06:41 PM
Anubyss's Avatar
Default 720cc with Hondata
Could anyone running this setup (espcially a Prelude) answer some questions for me? How is the idle (daily driver)? What fuel setup are you using? What's the highest boost you've run and what is the power? I am trying to decide whether or not to install the 720cc injectors and upgrade to an external pump. I am thinking around 20psi should be the limit for a safe daily driven car RUNNING ON HONDATA. Any info would be greatly appreciated.
Old May 15, 2003 | 07:25 PM
FIxALPHA's Avatar
Default Re: 720cc with Hondata (Anubyss)
I have 72lb injectors with a high flow intank pump.
Idles fine, but sometimes when I open it up and put it to neutral, or stop at a light the engine dies.
Go for it.
Old May 15, 2003 | 07:57 PM
Anubyss's Avatar
Default Re: 720cc with Hondata (FIxALPHA)
You are running on the Walbro 255 high pressure intank I am assuming? One of the things I am wondering is if that intank will be reliable pushing fuel to 720cc injectors over a long period. I don't mean boost duration but just wear and tear on the unit. Things could go bad quickly if it were to ever happen. Thanks for the info.
Old May 15, 2003 | 09:15 PM
FIxALPHA's Avatar
Ive had the same fuel pump for three years now. Still holding up.
Old May 15, 2003 | 09:17 PM
gsrt's Avatar
i use greddy 720cc with hondata and nos external fuel pump with 8AN fuel line for daily drive. i max out at 17psi but it depend on your turbo setup.
Old May 16, 2003 | 05:12 AM
Anubyss's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIxALPHA &raquo;</TD></TR><TR><TD CLASS="quote">Ive had the same fuel pump for three years now. Still holding up. </TD></TR></TABLE>
Ah that's good to hear. I want to run 20psi just for track runs. The 550cc and the Walbro seem fine right now and I was just wondering how it would handle 720cc.
97dc2
May 30, 2005 10:30 PM
RedZone
Oct 2, 2004 08:59 PM
ELSpool
May 26, 2004 12:11 PM
Precision DC4
Oct 25, 2002 09:18 AM
smoothludey2
Oct 1, 2001 03:27 PM
