how to identify if your b16a1 came from automatic car?
Old Feb 1, 2002 | 10:31 AM
civicguy's Avatar
Default how to identify if your b16a1 came from automatic car?
im going to buy a b16a1 from hodamotors,its only the short block,but im scared this guy is gonna sell me the engines from an automatic car,i heard they are weak,help ,please
Old Feb 1, 2002 | 10:33 AM
crxgurlllll's Avatar
Default Re: how to identify if your b16a1 came from automatic car? (civicguy)
the difference between a 5 speed and an AT is the cams(thats it)
Youll be able to tell by the manifold(itll have extra vaccum connections) and the drive plate will have AT stamped on the nuts(unless hes changed it of course)
Old Feb 1, 2002 | 10:35 AM
markedOO1's Avatar
Default Re: how to identify if your b16a1 came from automatic car? (eraser)
...and it'll have a flex plate and not a flywheel.
Old Feb 1, 2002 | 02:33 PM
QWKPHKR's Avatar
Default Re: how to identify if your b16a1 came from automatic car? (marked001)
I thought that the engines are the same, well performance wise. Would you be able to tell if you had a b16 from an automatic car for a 5spd car...
Old Feb 1, 2002 | 02:36 PM
Default Re: how to identify if your b16a1 came from automatic car? (QWKPHKR)
the cams are milder on an automatic
Old Feb 1, 2002 | 03:58 PM
CRX-RX's Avatar
Same cams, weaker valve springs.
Old Feb 1, 2002 | 04:26 PM
SiR831's Avatar
well AT block will have flex plate and 5spd will have a clutch, flywheel etc.......
and i recall people saying 5spd B16a has dual valve springs and AT doesn't
[Modified by SiR831, 5:29 PM 2/1/2002]
Old Feb 1, 2002 | 05:02 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: how to identify if your b16a1 came from automatic car? (SiR831)
Boy, there is a lot of missinformation on the net.
Both engines are identical, same cams, same springs, same everything else.
the difference is in the ECU.
Automatic transmissions on B16 came only on the Integra Xsi, and it had a PR3 ECU. The ECU limits the engine to 7600 RPM to protect the transmission, not the engine. The ECU also reduces power at the shift points in order to protect the transmission from shifting at full power.
EKCRX-Ihadastupidusername
13
Jun 24, 2005 12:39 PM
mmuller
Dec 15, 2002 03:46 PM
iwhichisme
Apr 14, 2002 11:56 AM
D1ANCER
Apr 10, 2002 11:54 AM
RR98DX
Mar 29, 2002 02:05 PM
