Headgasket problem?
Old Apr 27, 2005 | 02:01 AM
Mohsin's Avatar
Default Headgasket problem?
Car has done 120kmiles, D15B2. Driving normally seen temp gauge reach half and slowly rising(never goes above 40%), and then pulled over coolant fluid poures out.
Re-filled with coolant, radiator seems to be leaking now, for some reason oil looks fine (no milky stuff), car has not overheated since the incident. When i opened the rad cap and rev'd slightly rad starting foaming with bubbles and after 1.5krpm fluid jumps out.
I'v yet to do compression test but looks like the gasket. Any thing else i could check? All help appreciated.
Thanks
Old Apr 27, 2005 | 06:55 AM
Mohsin's Avatar
Default Re: Headgasket problem? (Mohsin)
can any one please help? Thanks.
Old Apr 27, 2005 | 08:01 AM
Deemeetree's Avatar
Electrician
Where does the coolant come out of? Have you checked the condition of the thermostat? Have you changed your water pump recently?
Best thing to do is strart doing routine maintenance.
Thermostat
Water Pump
Timing Belt
Make sure your fan is working properly.
flipldls
May 9, 2010 02:14 PM
Doylerules4588
11
Jul 3, 2008 08:01 PM
klion22
May 27, 2008 12:28 PM
regdog77
Apr 12, 2007 04:44 PM
pentaq
Sep 13, 2005 03:19 PM
