HELP! cooling system problem.
Old Apr 10, 2007 | 06:52 PM
regdog77's Avatar
Default HELP! cooling system problem.
I have a 96gsr 4dr with 309k. Lately I have been having problems with my cooling system.The reservoir keeps filling with coolant and does not return to the radiator. I have replaced the thermostat and radiator cap with oem parts, the upper hose and have flushed the coolant 2x. There is no oil in my fluid and I am not overheating. I also have no leaks. What could be the problem? Is it my radiator?
Old Apr 10, 2007 | 07:31 PM
shad0wslay3r's Avatar
Default Re: HELP! cooling system problem. (regdog77)
Is your water pump circulating the coolant..?
Old Apr 10, 2007 | 07:35 PM
regdog77's Avatar
How can you tell? I took the rad cap made sure most of air was out.
Old Apr 10, 2007 | 11:00 PM
regdog77's Avatar
bump
Old Apr 11, 2007 | 09:33 AM
regdog77's Avatar
help
Old Apr 11, 2007 | 10:00 AM
jizzer671's Avatar
Default Re: HELP! cooling system problem. (shad0wslay3r)
[QUOTE=shad0wslay3r]Is your water pump circulating the coolant..?[/QUO
have you ever had the water pump changed? i would check the water pump if you havent changed it at all? its definately time @ 309k.
Old Apr 11, 2007 | 10:05 AM
im_poor's Avatar
Default Re: HELP! cooling system problem. (jizzer671)
309k miles
Old Apr 11, 2007 | 06:00 PM
regdog77's Avatar
I changed the water pump last year with the timing belt. Do you think that i have a slow leak on my head gasket?
Old Apr 12, 2007 | 04:44 PM
regdog77's Avatar
bump
DumaDA
Jun 25, 2011 12:50 PM
Null zahlen
19
Sep 14, 2009 02:10 PM
warlockip
Oct 6, 2008 09:02 AM
klion22
May 27, 2008 12:28 PM
