ATTN ALL LS/VTEC DAILY DRIVER OWNERS!!!
i wanted to know setups are you guys running.i have a b18b motor in my eg now and i wanted to get an idea what i had to do to get good power and also have a reliable motor.thanks.
also i searched already and nothing really came up with daily driven ls/vtec..thanks in advance!
My build
B16a Head w/ GSR cams
B18b Block w/ P30 pistons mounted on stock ls rods
Here's my parts list:
Golden Eagle LS\Vtec kit
P30 Honda OEM Piston Ringset
ACL Bearings
Golden Eagle Head Studs
ITR Oil Pump
ITR Water Pump
ITR T-belt
ARP Rod Bolts
ITR Intake Manifold
B18b TB bored by maxbore
Once I get a little more cash I plan on upgrade my valvetrain.
ACL Bearings
ITR Oil Pump
ITR Water Pump
ITR T-belt
ARP Rod Bolts
ITR Intake Manifold
im running a b18a1 block, gsr head
p30 pistons (jdm b16)
jun III cams
skunk 2 valvetrain and cam gears
ARP headstuds
cometic MLS headgasket
jun III cams
ARP headstuds
b18b block
p30 b16 head, milled .040
camp1320 cam gears
cometic xtreme head gasket
p30 pistons on custom age eagle rods
micropolished jomar racing b18 crank
ctr crank pulley
aebs headstuds
ITR oil pump
ITR water pump
ITR manifold
hondata intake manifold gasket
bored b16 throttle body, matched to IM
ACL bearings
JDM DC 4-1 Header
AEM CAI
Accel wires
NGK BRK6 plugs
3-angle valvejob
GE ls/vtec oil feed kit
ih8ricerz ls/vtec chipped p28 ecu
a/c-p/s-cc removed
Koyo aluminum radiator
mugen thermostat
ys1 hydro b16 tranny
clutchmasters 11-lb.flywheel
greddy sp straight exhaust
straight pipe
stock valvetrain/cams
stock clutch
stock fpr, pump
....lookin at RM m22's/valvetrain, hondata, clutch upgrade ASAP.....
Modified by sik_sol at 4:46 PM 4/26/2005
camp1320 cam gears
ctr crank pulley
aebs headstuds
ITR oil pump
ITR water pump
ITR manifold
ACL bearings
JDM DC 4-1 Header
AEM CAI
Accel wires
NGK BRK6 plugs
3-angle valvejob
a/c-p/s-cc removed
mugen thermostat
straight pipe
stock clutch
stock fpr, pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MichaelPal »</TD></TR><TR><TD CLASS="quote">b18b block
b18c head
11.9 CR
probe rods
type-r cams
full exahsut
AEM CAI
hondata s200
Edit: sik_sol...waht kinda power u laying down?</TD></TR></TABLE>
not sure yet main....waiting to get it to the dyno that just opened up 10 minutes from herre....somewhere in the high 180ishwhp hopefully.....i think 200 is out of the question til cams are installed...but we'll see....
what about u dude??
b18c head
11.9 CR
probe rods
type-r cams
full exahsut
AEM CAI
hondata s200
what about u dude??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH 7 »</TD></TR><TR><TD CLASS="quote">hey can you guys put down how much power you guys are making please...thanks</TD></TR></TABLE>
dude, no offense, but is there anything that you DO like about H-T??
also i searched already and nothing really came up</TD></TR></TABLE>
you didnt search hard enough. plus you have to realize that you cant just type in a question and the answer pops up, it takes some research and some digging around. but your lucky im in a good mood today
these are some i thought would help.
https://honda-tech.com/zerothread?id=798832
https://honda-tech.com/zerothread?id=1042982
https://honda-tech.com/zerothread?id=752996
and, of course the best thread on h-t.
https://honda-tech.com/zerothread?id=1118097
these are some i thought would help.https://honda-tech.com/zerothread?id=798832
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">
this is an ls/vtec thread playa...wheres ur set up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik_sol »</TD></TR><TR><TD CLASS="quote">
this is an ls/vtec thread playa...wheres ur set up?</TD></TR></TABLE>
im in the process of building:
b18a
micro-polished crank
balanced complete bottom end
large end of rods re-sized
all new acl bearings
arp rod bolts
new oem OS pr3's
new oem rings
new oem vtec oil/water pump
gsr girdle with gsr mains/windage tray/pick-up/oil pan
gsr head
RM valve train
RM cams(still undecided on which ones)
skunk/blox IM
skunk cam gears
did i pass the test, playa?
<FONT SIZE="6">NOW BUY MY WHEELS SO I CAN FINISH MY BUILD</FONT>
b18a
arp rod bolts
new oem OS pr3's
new oem rings
gsr head
RM valve train
skunk/blox IM
skunk cam gears
