converting from Obd-2a to Obd-1...what ecu should i use? basic bolt ons...
Old Apr 25, 2005 | 03:40 PM
esoterEK..'s Avatar
Default converting from Obd-2a to Obd-1...what ecu should i use? basic bolt ons...
im running obd-2a in an ek and i just wanna convert to obd-1 to knock out all the unessary sensors, check engine codes etc....
my motor is basically stock: skunk IM, 65mm TB, headers, intake, exhaust etc..
no internal work..
im just wondering what obd-1 ecu should i use to run on my car for now?
any help would be greatly appreciated. thanks!!!
Im running a '00 B18C1
Modified by esoterEK.. at 9:27 PM 4/25/2005
Old Apr 25, 2005 | 03:46 PM
TeamNextGenChris's Avatar
Default Re: converting from Obd-2a to Obd-1...what ecu should i use? basic bolt ons... (esoterEK..)
telling us what motor you have would be a huge help
Chris
Old Apr 25, 2005 | 04:03 PM
d16y8EL's Avatar
my guess is d16y8
Old Apr 25, 2005 | 04:06 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (d16y8EL)
So you're hoping by running a different ECU it will "magically" cure all your CEL's? Good logic.
Old Apr 25, 2005 | 04:35 PM
99TurboFerio's Avatar
Ive got a 99 and i converted to OBDI also. get a p28 ecu from a 92-95 civic and a ob2-to-obd1 conversion harness. I found both mine on ebay for under 150 bucks works perfect. knocked all the sensors off that shouldnt be on. But didnt have any on before so im assuming you didn't either.
Old Apr 25, 2005 | 05:16 PM
esoterEK..'s Avatar
Default Re: converting from Obd-2a to Obd-1...what ecu should i use? basic bolt ons... (99TurboFerio)
2000 gsr motor
running 97 gsr ecu right now...
its throwing that annoying code 91 that most ek swaps have.
it doesnt affect the performance of the car though.
i got a obd2a-obd1 harness laying around.
why not use it.
Modified by esoterEK.. at 9:26 PM 4/25/2005
Old Apr 25, 2005 | 11:33 PM
wtf is on you're intake ive never seen that before i feel very dumb.
jdmjunior1991
Mar 11, 2014 05:19 AM
turbod16y8
13
Apr 7, 2011 02:40 PM
BrandonB16
Feb 17, 2009 05:33 AM
Razr2
13
Jan 28, 2008 01:54 AM
turbo00civ
11
Jun 10, 2006 02:12 PM
