Help...JDM B18C
Old Apr 25, 2005 | 05:49 AM
CivicHB93JDM's Avatar
Default Help...JDM B18C
Hello Everyone,
I am almost done with my JDM B18C swap into my 93 CX Civic HB . I ran into a small problem when I was ready to plug the wire harness. Has anyone on here done a true JDM B18C(JDM SiR-G) swap . Since it came off of a right hand car. The wire seems to be in reverse order. I have searched on here for hours and came up empty. Please help, thanks.
Old Apr 25, 2005 | 06:39 AM
CA6VTEC's Avatar
Default Re: Help...JDM B18C (CivicHB93JDM)
<FONT COLOR="royalblue"> You're not supposed to use the JDM harness. Just use the stock cx harness & add the necessary wires & plugs. </FONT>
Old Apr 25, 2005 | 06:41 AM
GetawayInMoscow's Avatar
Default Re: Help...JDM B18C (CA6VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CA6VTEC &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="royalblue"> You're not supposed to use the JDM harness. Just use the stock cx harness & add the necessary wires & plugs. </FONT></TD></TR></TABLE>
Old Apr 25, 2005 | 06:46 AM
T4eg's Avatar
i did a "true" jdm b18c into my eg's and thats what i did
Chris
Old Apr 25, 2005 | 07:10 AM
Littlegreend15's Avatar
Default Re: Help...JDM B18C (BlueHatch00)
just extend all the wires, its kinda time consuming, but it works
so basically, what you all are saying is pull the harness from the stock motor D15 and add it to the B18C motor?
Old Apr 25, 2005 | 08:14 AM
CA6VTEC's Avatar
Default Re: (CivicHB93JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHB93JDM &raquo;</TD></TR><TR><TD CLASS="quote">so basically, what you all are saying is pull the harness from the stock motor D15 and add it to the B18C motor?</TD></TR></TABLE>
<FONT COLOR="royalblue"> Yes. Most of the sensor plug right in. The Intake Temp Sensor needs to be extended. You will need to add the plugs for the VTEC solenoid, VTEC Pressure Switch, Knock Sensor & convert your 1 wire O2 sensor to 4 wire. My solution was to use an Ex harness, which has all the plugs, except the Knock, or use a USDM B18c1 Harness, which has all the plugs. </FONT>
Old Apr 25, 2005 | 09:05 AM
Default Re: (CA6VTEC)
hey thanks, I will give it a try.
jdmstyleEJ6
15
Feb 4, 2010 09:40 PM
street95civic
Aug 22, 2005 08:23 AM
Mischief_EG
15
Jun 15, 2004 07:56 PM
mishimamadness
Apr 15, 2004 10:26 AM
95civichb
Jan 25, 2004 06:26 PM
