F22b1 sohc vtec into ek chassis
Old Apr 21, 2005 | 08:07 PM
kracer's Avatar
Default F22b1 sohc vtec into ek chassis
I saw this sleeved f22b block on here for sale and I was wondering what are the major things needed to put it into a ek. I need more help in the wiring of the engine. I know some of the sensors are different in the f22b. I tried the search but didn't find anything that was real helpful. If i'm correct you use the h22 mount kits. Pending if they come with those h2b series adapter plates I might consider one of those too.
Old Apr 22, 2005 | 01:13 PM
kracer's Avatar
Default Re: F22b1 sohc vtec into ek chassis (kracer)
anybody
Old Apr 22, 2005 | 01:26 PM
Deemeetree's Avatar
Electrician
You'll need to mount it as if you were mounting an H22. You'll need to use a 1996-1997 setup where it's OBD-2. 1994-1995 are OBD-1.
Old Apr 22, 2005 | 01:58 PM
KENetics1's Avatar
I thought acouple of the sensors on the accord engine harness are in different spots so you have to re pin the harness on the engine side.
Modified by KENetics1 at 5:15 PM 4/22/2005
Old Apr 23, 2005 | 03:06 PM
kracer's Avatar
ttt...what about the engine harness? Does the accord engine harness even plug into a civic?
Old Apr 23, 2005 | 03:10 PM
Deemeetree's Avatar
Electrician
Get a hold of the engine harness and sensor wiring schematics and find out.
Old Apr 24, 2005 | 12:56 PM
O3DigitalBath's Avatar
^why post if you don't have any idea....
just use a civic harness for the swap, you'll have to change the injector plugs and add a resistor box, lengthen a few random wires (depends on how you do it) and for sure lengthen the alternator wires...
use h22 mounts, and you'll also need to get a lude/accord shiftlinkage/assem. becuase they use cable shifter setups unlike the rod type with b/d series.
jimlaH
Apr 14, 2010 09:53 PM
HarosGSRek
17
Mar 29, 2009 10:37 AM
EK22Tim
Aug 19, 2002 11:40 AM
