F22b1 sohc vtec into ek chassis
I saw this sleeved f22b block on here for sale and I was wondering what are the major things needed to put it into a ek. I need more help in the wiring of the engine. I know some of the sensors are different in the f22b. I tried the search but didn't find anything that was real helpful. If i'm correct you use the h22 mount kits. Pending if they come with those h2b series adapter plates I might consider one of those too.
Re: F22b1 sohc vtec into ek chassis (kracer)
I thought acouple of the sensors on the accord engine harness are in different spots so you have to re pin the harness on the engine side.
Modified by KENetics1 at 5:15 PM 4/22/2005
^why post if you don't have any idea....
just use a civic harness for the swap, you'll have to change the injector plugs and add a resistor box, lengthen a few random wires (depends on how you do it) and for sure lengthen the alternator wires...
use h22 mounts, and you'll also need to get a lude/accord shiftlinkage/assem. becuase they use cable shifter setups unlike the rod type with b/d series.
