GSR motor with LSD Turbo or Gsr head with ls/vtec turbo and with LSD
Old Apr 19, 2005 | 11:40 PM
Race Whore's Avatar
Default GSR motor with LSD Turbo or Gsr head with ls/vtec turbo and with LSD
Which would be better for relibility and speed on the quarter mile? Anyone with experience on both setups please give any pros and cons.
thx
Old Apr 19, 2005 | 11:52 PM
hatchling37's Avatar
Default Re: GSR motor with LSD Turbo or Gsr head with ls/vtec turbo and with LSD (Race *****)
Well, due to the additional torque you're going to generate, I would say the Frankenstein, all other things being equal
Old Apr 20, 2005 | 09:05 AM
Race Whore's Avatar
Default Re: GSR motor with LSD Turbo or Gsr head with ls/vtec turbo and with LSD (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Well, due to the additional torque you're going to generate, I would say the Frankenstein, all other things being equal</TD></TR></TABLE>
Thx for the last post..... Is there anyone else that has had experienced with this setup?
Old Apr 20, 2005 | 09:09 AM
92CivicSIRhb's Avatar
the ls/vtec turbo will create alot of torque. and torque does help when your trying to run a straight line in a hurry. good hp too.
Old Apr 20, 2005 | 10:29 AM
turboEGhatch's Avatar
Default Re: GSR motor with LSD Turbo or Gsr head with ls/vtec turbo and with LSD (92CivicSIRhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92CivicSIRhb &raquo;</TD></TR><TR><TD CLASS="quote">the ls/vtec turbo will create alot of torque. and torque does help when your trying to run a straight line in a hurry. good hp too.</TD></TR></TABLE>
The LS stroke is about 0.07" longer than the GSR stroke. You won't feel crap for a difference in low end, the only difference you'll feel is the IMAGINARY difference in your head because you think your motor is making way more torque because of the super huge LS stroke torque.
The reason LS-turbo cars make so much torque at X amount of WHP is because they typically run a lot more boost to make the same amount of horsepower. 14 pounds of boost hitting at 4000 RPM's will boost your peak torque much higher than running 8 pounds on a GSR motor, where most of the horsepower gain comes from the improved head and camshafts on the top end.
Running an LS/VTEC is not a magical way to make pounds and pounds more torque than a GSR!
DJNauTicz
32
Oct 16, 2007 10:03 AM
Mr.Death
Jul 28, 2005 10:51 AM
Race Whore
Apr 20, 2005 02:43 PM
ChinitodeNJ
Jan 10, 2005 10:42 AM
dohc-nyne
Apr 11, 2003 11:09 PM
