Car pulling from side to side.
Old Jul 27, 2005 | 07:47 PM
Mr.Death's Avatar
Default Car pulling from side to side.
I recently had an Edelbrock turbo kit installed on my rex (7lbs)along with a d16z6 motor and a sohc LSD tranny. When I get on the gas(hard!) the car pulls from side to side and feels unstable. Is this normal for a turbo car or does it sound like my lsd is worn out.
Thanks much......
Old Jul 27, 2005 | 07:52 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Car pulling from side to side. (Mr.Death)
welcome to the world of torque steer
Bailhatch's Avatar
toe (out) or bad front lower control arm bushings are common reasons for this.
Old Jul 27, 2005 | 07:56 PM
YiNYaNg's Avatar
Default Re: Car pulling from side to side. (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">welcome to the world of torque steer</TD></TR></TABLE>
I hate it....
Old Jul 27, 2005 | 08:04 PM
Mr.Death's Avatar
I have polyurethane bushings in my controll arms and I thought you only get torque steer from trannys without the lsd. Isn't the lsd supposed to eliminate torque steer?
Old Jul 27, 2005 | 08:17 PM
beepy's Avatar
Default Re: (Mr.Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote"> Isn't the lsd supposed to eliminate torque steer?</TD></TR></TABLE>
Not as long as you have one CV axle longer than the other.
You really just need to get used to it.
Old Jul 27, 2005 | 08:37 PM
Mr.Death's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">
You really just need to get used to it.</TD></TR></TABLE>
I have equal length shafts. Must be time for an alognment
Old Jul 27, 2005 | 09:18 PM
Muckman's Avatar
Moderator in Chief
Not if you have a D series.
Old Jul 27, 2005 | 09:37 PM
ramennoodles's Avatar
Default Re: (Muckman)
viscous or helical or what type of lsd? viscous may need a different type of gear oil
Old Jul 27, 2005 | 09:44 PM
lucidvtec's Avatar
alignment check ur bushings....and it could be ur lsd
Old Jul 27, 2005 | 09:51 PM
Mr.Death's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Not if you have a D series.</TD></TR></TABLE>
THe tranny is from a Japanese ZC which uses an intermediate shaft making the drive shafts "equal length".
Old Jul 27, 2005 | 10:03 PM
BoOsTiN Dc2's Avatar
my car does that too... it swerves in high rpm sometimes. its something thats fucked up on my car maybe suspension or alignment.
Old Jul 27, 2005 | 10:04 PM
wantboost's Avatar
Who is Mr Robot?
one is still slightly longer than the other. go check
Old Jul 28, 2005 | 06:15 AM
Muckman's Avatar
Moderator in Chief
I stand corrected. It has to be something related to your alignment then.
Old Jul 28, 2005 | 10:22 AM
hyabusa hunter's Avatar
THe tranny is from a Japanese ZC which uses an intermediate shaft making the drive shafts "equal length". </TD></TR></TABLE>
its a wanna-be equal length. still would have problems with shaft whip. H22s have the same thing. On an H22 Civic the shafts are fairly close in length. about 2 inches difference and the car has horrible torque steer. The only real equal length drive shaft equipped Honda that I know of is a B16 equipped Civic with the right tranny (want to say JDM YS1...B16 gods please correct me if I am wrong).
lmao. so true man so true!!!!
Old Jul 28, 2005 | 10:51 AM
EGP's Avatar
EGP
Get your alignment checked.
vtec_crazy
Jul 7, 2005 03:55 PM
ITR1078
12
Apr 13, 2005 09:05 PM
pkt1213
Jan 30, 2005 01:04 AM
otakueric
May 23, 2004 05:33 PM
yellow eg
Sep 24, 2003 11:47 PM
