wiring up for b16a sir2 into 94 cx
Old Apr 19, 2005 | 08:04 AM
komat's Avatar
Default wiring up for b16a sir2 into 94 cx
im half way done doing my b16a sir2 swap into my 94 cx
i want to make sure i have all the wiring correct using my stock cx harness
i need the following wiring to do
3 vtec wires
1 knock sensor
1-4 wire o2sensor
someone told me i would need to do the map sensor too?
if i let out any other wiring to do please let me know
Old Apr 19, 2005 | 01:16 PM
komat's Avatar
Default Re: wiring up for b16a sir2 into 94 cx (komat)
bump
Old Apr 19, 2005 | 01:24 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">im half way done doing my b16a sir2 swap into my 94 cx
3 vtec wires
1 knock sensor
1-4 wire o2sensor
if i let out any other wiring to do please let me know</TD></TR></TABLE>
you will need to add;
2 VTEC wires (signal and oil pressure)
1 knock sensor (if you're using a P30, a P28 does not need this)
1 O2 heater signal, other two wires connect under the hood and you use the existing O2 signal wire.
Old Apr 19, 2005 | 01:27 PM
jbscivichb92's Avatar
Default Re: wiring up for b16a sir2 into 94 cx (Relic1)
don't forget about vtec ground. just ground it to the chassis.
Old Apr 19, 2005 | 04:46 PM
komat's Avatar
Default Re: wiring up for b16a sir2 into 94 cx (jbscivichb92)
thanks for the reply
my finger tip hurts from taking all the connectors off
coffee_junkee
Dec 14, 2008 03:13 PM
JLefevers
16
Jul 17, 2008 10:31 PM
Tad
14
Jun 29, 2004 09:22 AM
robest08
48
Jun 5, 2003 10:30 PM
Lysawy
Oct 21, 2002 08:15 PM
