Is it worth boostin on a D16
Old Apr 19, 2005 | 05:32 AM
jdm-94dc2's Avatar
Default Is it worth boostin on a D16
I've been ponding for a while if i should boost my d16vtec or save for a swap...what do you guys think...i was thinking of getting a Greddy kit...need some serious advice
Old Apr 19, 2005 | 05:41 AM
Synapse Motorsport's Avatar
Default Re: Is it worth boostin on a D16 (TOPSHOTTA-93eg6)
Boost the d16, you will have alot of fun with it, and the greddy kit will work well with the stock motor, unless you want to upgrade later, then make urself a custom kit, capable of more power.
Old Apr 19, 2005 | 05:57 AM
CivicEX96's Avatar
I use to have a greddy turbo kit with a HKS SSQ BOV on my d16y8 last year, and i loved it! if your the kind of guy that wants to make your stock d-series faster but not really hardcore in going through the motor swap process, then d series turbo is the way to go...its the only way to make real power on a d-series and its alot of fun...the best advice i can give you since your around my age is to make sure you save up your money until you are certain you can afford the kit and all the other necessary parts to run it right the first time...and also have some money left over so your not completely broke after you purchase...because i made this mistake and ended up blowing my motor
Old Apr 19, 2005 | 06:10 AM
fjt's Avatar
fjt
Default Re: Is it worth boostin on a D16 (CivicEX96)
Hmmm lets see
B18c1 Swap is around 3,500...depending on what Car you have you can run between high 14's to low 14's stock...
With the same amount you can run a custom turbo setup on your d and run 13's..Heck even 12's..Look at Beerbongkicksass setup..Stock D series motor with a turbo and he runs mid 12's
Old Apr 19, 2005 | 06:18 AM
Bailhatch's Avatar
Default Re: Is it worth boostin on a D16 (fjt)
Also, if youre concerned with not just straight line performance the D series motor and tranny is quite a bit liighter. Better turn in, overall lighter weight, better weight distribution...all good things for going fast
Old Apr 19, 2005 | 06:19 AM
CivicEX96's Avatar
btw...
check out this website for more info...
http://www.turbod16.com/
1SlowSi's Avatar
it depends on how much power you want. 200-220whp is quite fun. But you wil want more later.
Old Apr 19, 2005 | 06:37 AM
oxSLEEPERxo's Avatar
Default Re: Is it worth boostin on a D16 (1SlowSi)
go d16 turbo I reccomend you to build a custom one, so you get to pick the parts that you want
Old Apr 19, 2005 | 06:39 AM
blackeg's Avatar
Default Re: Is it worth boostin on a D16 (oxSLEEPERxo)
boosting the d16 is worth it.
Old Apr 19, 2005 | 06:42 AM
evosol's Avatar
Default Re: Is it worth boostin on a D16 (blackeg)
by the way check out homemadeturbo.com
Old Apr 19, 2005 | 06:45 AM
YiNYaNg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">it depends on how much power you want. 200-220whp is quite fun. But you wil want more later.</TD></TR></TABLE>
It'll start feeling like it's slow after you get use to the power...lol..
but yet again I am addicted to boost... always craving for more boost...
Old Apr 19, 2005 | 06:47 AM
EJ1 wilcox's Avatar
Default Re: Is it worth boostin on a D16 (evosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEX96 &raquo;</TD></TR><TR><TD CLASS="quote">... make sure you save up your money until you are certain you can afford the kit and all the other necessary parts to run it right the first time...and also have some money left over so your not completely broke after you purchase...because i made this mistake and ended up blowing my motor </TD></TR></TABLE>
Definately... you have to figure in the cost of all the extra stuff that you are going to have to spend money on...
I had to replace my clutch within a few weeks of putting my turbo on because of the power, then a few months later I did a head gasket.... who knows whats next!
Old Apr 19, 2005 | 07:53 AM
jdm-94dc2's Avatar
THANKS FOR ALL THE INFO...but what kit do you guys recommend
Old Apr 19, 2005 | 07:58 AM
Civicman86's Avatar
Definatly boost the D. I just got installing mine a weekend ago and I dotn regret it yet. I think especially for steet driven daily driver a d sereis will meet all your goals. For 3,500 bucks you could have a nice setup.
Also read up and make sure you know what problems people have with d series (heads lifting and the small rods). Other than those two they seem to be great!
Old Apr 19, 2005 | 08:38 AM
JDMCRX's Avatar
Default Re: (Civicman86)
Guy boosted D series at 8psi with some mods the **** pulls i made 205WHP with a stock exhaust and was very close with a New C5 but got a exhaust and skunk2 intake and few more bolt ons same boost 225whp and i pull on them now at 11psi with a ported head i made 256whp car was fast
ELSPOOL at 17psi made 297whp and he pulls on Z06's and so forth
Spend all that cash on a ITR swap or GSR u are no were near 200whp
Old Apr 19, 2005 | 09:21 AM
YiNYaNg's Avatar
Default Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Guy boosted D series at 8psi with some mods the **** pulls i made 205WHP with a stock exhaust and was very close with a New C5 but got a exhaust and skunk2 intake and few more bolt ons same boost 225whp and i pull on them now at 11psi with a ported head i made 256whp car was fast
Spend all that cash on a ITR swap or GSR u are no were near 200whp</TD></TR></TABLE>
That's right!
Old Apr 19, 2005 | 09:47 AM
jdm-94dc2's Avatar
whats the best sohc kit to get
Old Apr 19, 2005 | 10:04 AM
sadangryboi's Avatar
make your own, pick the parts u want and go good with your car.
Old Apr 19, 2005 | 10:52 AM
jdm-94dc2's Avatar
Default Re: (sadangryboi)
It's it more money when you do it like that?
Old Apr 19, 2005 | 01:03 PM
Civicman86's Avatar
Default Re: (TOPSHOTTA-93eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOPSHOTTA-93eg6 &raquo;</TD></TR><TR><TD CLASS="quote">It's it more money when you do it like that?</TD></TR></TABLE>
You can spend the same amount of money on a custom kit and get better power. Just reasearch and look around for good deals. Both are everywhere . SOHC people are good people to help you out too.
Old Apr 19, 2005 | 03:21 PM
baphomet's Avatar
If you boost the D, you become a certified ninja...I here
Old Apr 19, 2005 | 03:32 PM
yellowturbo's Avatar
boost it you wont regret it... the greddy kit is really easy to install and reliable... be carefulyou will always want more and it could be expensive.
Old Apr 19, 2005 | 03:48 PM
mattssi's Avatar
I have 2 honda civics that are turbo'd with d series. One with a d16y7/z6 combo, and the other is a straight y8. Both are fun as hell to drive and reliable. My hatch I tool to 14psi at the drags last time on accident, still running strong.
slow_redcivic
17
Feb 26, 2006 10:00 AM
trooper0641
21
Apr 13, 2004 11:08 PM
-BlueGSR-
Apr 24, 2003 09:52 AM
td04civic
Oct 5, 2002 10:13 AM
89hybrid
Sep 20, 2001 09:55 PM
