how is this possible, what can be wrong?
Old Apr 19, 2005 | 02:36 PM
J337_UNIT's Avatar
Default how is this possible, what can be wrong?
Not sure if this belongs in FI. But being i had my car retuned this weekend, i gotta post because i am BOGGLED. We tuned in open loop mode, everything was good, then after the tune, we set the chip for closed loop mode to utilize the stock o2 again. Only problem is now it seems like theres no reading coming from the stock o2 sensor. I can unplug the stock O2 sensor and NOTHING changes. It still idles like crap. But then when we set it to open loop mode, it idled good and ran fine.. what the hell is up?
Old Apr 19, 2005 | 02:42 PM
Bailhatch's Avatar
Default Re: how is this possible, what can be wrong? (J337_UNIT)
maybe running the stock O2 un-powered fouled it?
Old Apr 19, 2005 | 02:45 PM
mopar junkie's Avatar
Never run and O2 sensor unplugged.
Check the v-out with a volt meter.
Old Apr 19, 2005 | 02:48 PM
nonvtecD's Avatar
No, I ran a stock o2 sensor in my exhaust without having it hooked up just to plug my o2 hole because I was running open loop for a while. It still worked after 6 months Sometimes weird stuff like this happens. Not a very good answer but my car in open loop would never idle cold but then when it warmed up it mysteriously would get better as if it went into closed loop.
Old Apr 19, 2005 | 02:57 PM
J337_UNIT's Avatar
Default Re: (nonvtecD)
yea i dunno im still really confused. no clue how this is possible. you would think by unplugging the O2 sensor SOMETHING would have changed, but nothing did.
Old Apr 19, 2005 | 03:21 PM
B16Civic93's Avatar
Default Re: (J337_UNIT)
is it throwing a o2 sensor cel?
Old Apr 19, 2005 | 03:24 PM
J337_UNIT's Avatar
Default Re: (B16Civic93)
no its not. the tuner disabled the O2 sensor heater so it wouldnt throw a CEL. but still the fact that i can remove the o2 sensor and it has no effect on anything blows my mind.
Old Apr 19, 2005 | 03:35 PM
dustin's Avatar
Well are you turning the O2 heater back on when you plug the O2 sensor back in?
Old Apr 19, 2005 | 03:44 PM
mattssi's Avatar
Default Re: (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Well are you turning the O2 heater back on when you plug the O2 sensor back in?</TD></TR></TABLE>
ding ding ding... beat me to it.
Old Apr 19, 2005 | 03:48 PM
J337_UNIT's Avatar
no, it is disabled.
Old Apr 19, 2005 | 03:52 PM
dustin's Avatar
Well try that. The o2 sensor doesn't give any useful info unless it is hot.
bmoreb18c1
Aug 13, 2012 01:14 AM
88 EF Hatch
Engine Management and Tuning
Sep 23, 2009 07:23 PM
odishaw
Feb 16, 2008 08:34 AM
CivicDXRaceCar
May 30, 2005 05:59 AM
birz
Jan 14, 2004 04:39 PM
