Unorthodox Crank Pulley Timing marks
Old Apr 18, 2005 | 04:53 PM
SOHC_MShue's Avatar
Default Unorthodox Crank Pulley Timing marks
I'm tuning my friend's car and for some reason we can't get his ignition timing set right. The timing reads way advanced at the distributor even with it fairly retarded. Are the timing marks on the pulley off at all? I think it could be a problem with the ignition system, but i was just wondering if maybe it was the pulley.
Old Apr 18, 2005 | 05:39 PM
SOHC_MShue's Avatar
Default Re: Unorthodox Crank Pulley Timing marks (SOHC_MShue)
bump
Old Apr 18, 2005 | 05:43 PM
BrokenHatch's Avatar
jdm y0
ttt
Old Apr 18, 2005 | 09:24 PM
SOHC_MShue's Avatar
bump for info
Old Apr 19, 2005 | 01:20 AM
jdm y0
someone help shue out
Old Apr 19, 2005 | 10:51 AM
SOHC_MShue's Avatar
Default Re: Unorthodox Crank Pulley Timing marks (BrokenHatch)
up
Old Apr 19, 2005 | 11:02 AM
RacerXI's Avatar
Have you checked the timing manually? As habit, I always compare stock crank pulleys & cam gears to whatever I'm putting on. You might slide a stock pulley next to the UR to make sure the lines are in the right place. You might also check the timing marks are in place (crank to cam gear) also. HTH.
Old Apr 19, 2005 | 11:07 AM
SOHC_MShue's Avatar
Default Re: Unorthodox Crank Pulley Timing marks (RacerXI)
the crank and cam gears are all lined up TDC. He doesn't have a stock cam gear to line up against it either
Old Apr 19, 2005 | 01:06 PM
Muckman's Avatar
Moderator in Chief
How far is it off?
Old Apr 19, 2005 | 01:40 PM
SOHC_MShue's Avatar
Default Re: Unorthodox Crank Pulley Timing marks (Muckman)
with it set pretty close to the middle i can get the 3 lines to line up with the mark on the timing cover, but this is when i have the timing gun advanced to 16* so really i should be lining up the single line.
Old Apr 20, 2005 | 01:38 AM
boostinhatch's Avatar
^ no longer owns a honda
ttt
Old Apr 20, 2005 | 04:52 AM
Sinitron's Avatar
There's only usually 3 cut lines on the unorthodox pulley. The two lines that are close together are 14 / 18 deg.... you should be aiming for the middle.
The last mark that's another inch and change away is TDC line.
Old Apr 20, 2005 | 05:56 AM
SOHC_MShue's Avatar
Default Re: Unorthodox Crank Pulley Timing marks (Sinitron)
we were using an advance timing light. So with the timing light set at 16* we should be aiming for the single tdc line rather than the three lines, but we weren't even close to it.
Old Apr 20, 2005 | 08:10 AM
Muckman's Avatar
Moderator in Chief
no the TDC (white) mark is not 16*. the middle timing (red) mark is 16*. if you line it up with the tdc mark then your timing is at 0*. your aiming for the wrong line!
Old Apr 20, 2005 | 08:27 AM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">we were using an advance timing light. So with the timing light set at 16* we should be aiming for the single tdc line rather than the three lines, but we weren't even close to it. </TD></TR></TABLE>
With the crank set to TDC, there should be a mark 16degrees to the left of the TDC marker. Those are the 3 lines you mentioned, and those are what you should be aiming for.
Old Apr 20, 2005 | 09:13 AM
SOHC_MShue's Avatar
I have never seen anyone time it the way you described unless they have a timing gun that is non adjustable. If you have an adjustable gun then setting it to 16* you will aim for the tdc mark. I am positive about this. We even checked it on my friend's car and with the gun turned up to 16* it was aimed right at his tdc mark.
Old Apr 20, 2005 | 09:31 AM
SOHC_MShue's Avatar
https://honda-tech.com/zerothread?id=56937 see heres a thread i found about setting it with an advance timing light.
civiccoupe94
Jan 11, 2008 07:08 AM
Project_CD5
Jul 25, 2007 03:20 AM
SI_niki
11
Jul 3, 2004 02:06 PM
VisualEcstasy
Apr 15, 2003 09:00 AM
89JDMcrx
Sep 25, 2002 05:22 PM
Top
Follow Us
