how can you tell if your car is overheating if the temp gauge is broken
Old Apr 16, 2005 | 05:57 PM
civais's Avatar
Default how can you tell if your car is overheating if the temp gauge is broken
how can you tell if your car is overheating if the temp gauge is broken. I think I have a small wiring problem, temp gauge goes to hot when ever I put the left turn signal on. really started to do weird things after I replaced the temp sensor.
Old Apr 16, 2005 | 06:02 PM
SiR Inspired ED7's Avatar
Default Re: how can you tell if your car is overheating if the temp gauge is broken (civais)
i'd fix the needle, other than that i dont know...
Old Apr 16, 2005 | 06:09 PM
civais's Avatar
Default Re: how can you tell if your car is overheating if the temp gauge is broken (88 Crx Si)
i do not even want to think about getting uder there with a multi meter and trying to find the short. my overflow tank does not overflow or boil as I have seen in other cars that overheat
Old Apr 16, 2005 | 10:21 PM
egtwincam's Avatar
you can measure the voltage at your ect. engine coolant temp sensor. its a 2 wire sensor on the head. plug in some paper clips and check the voltage. when its normal operating temp it should be about .5 to . volts. any less than that it is overheating..
Old Aug 13, 2015 | 07:33 PM
gomer124's Avatar
when mine overheats, it always idles high then low very noticeably something wrong lol
Old Aug 13, 2015 | 09:20 PM
.Manny.'s Avatar
Touching My Member
10 year old thread bump?
Jesus can't even match this dude's resurrection skills.
Old Aug 13, 2015 | 10:16 PM
24TEN's Avatar
PHANTOM MENACE
Not a newb either, he's an 03
Old Aug 14, 2015 | 03:11 AM
Freemananana's Avatar
Maybe he sub'd to this thread and finally checked his email.
Also, I'd just install a $20 aftermarket temp sensor if you are worried. Run it through the firewall and drop it in your cup holder until you get everything sorted out.
ericrcan
Nov 19, 2012 12:00 PM
stocker2shocker91
Mar 24, 2008 01:19 PM
PearlWhiteAccord
Dec 20, 2004 06:43 PM
erniecars
Jun 14, 2002 11:48 PM
pmachan
Aug 9, 2001 06:43 AM
