Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda CRX / EF Civic (1988 - 1991) (https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/)
-   -   how can you tell if your car is overheating if the temp gauge is broken (https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-can-you-tell-if-your-car-overheating-if-temp-gauge-broken-1215486/)
civais 04-16-2005 05:57 PM
how can you tell if your car is overheating if the temp gauge is broken. I think I have a small wiring problem, temp gauge goes to hot when ever I put the left turn signal on. really started to do weird things after I replaced the temp sensor.
SiR Inspired ED7 04-16-2005 06:02 PM
Re: how can you tell if your car is overheating if the temp gauge is broken (civais)
i'd fix the needle, other than that i dont know...
civais 04-16-2005 06:09 PM
Re: how can you tell if your car is overheating if the temp gauge is broken (88 Crx Si)
i do not even want to think about getting uder there with a multi meter and trying to find the short. my overflow tank does not overflow or boil as I have seen in other cars that overheat
egtwincam 04-16-2005 10:21 PM
you can measure the voltage at your ect. engine coolant temp sensor. its a 2 wire sensor on the head. plug in some paper clips and check the voltage. when its normal operating temp it should be about .5 to . volts. any less than that it is overheating..
gomer124 08-13-2015 07:33 PM
when mine overheats, it always idles high then low very noticeably something wrong lol
.Manny. 08-13-2015 09:20 PM
10 year old thread bump?
Jesus can't even match this dude's resurrection skills.
24TEN 08-13-2015 10:16 PM
Not a newb either, he's an 03
Freemananana 08-14-2015 03:11 AM
Maybe he sub'd to this thread and finally checked his email.
Also, I'd just install a $20 aftermarket temp sensor if you are worried. Run it through the firewall and drop it in your cup holder until you get everything sorted out.
