5th gen Brake problem ---- Cont.
Old Apr 16, 2005 | 11:52 AM
RUBZERK's Avatar
Default 5th gen Brake problem ---- Cont.
OK now I posted my problem last week & I did what a few of you guys suggested.
https://honda-tech.com/zerothread?id=1206878
<U>Heres a recap of the problem</U>
<U>The car </U>- 95 Accord lx 4 door w/ ABS
<U>The problem</U> - as I press the break pedal, it tends to go to the floor & just slow down the car, but not really. If I pump the break pedal 2 times it works fine.
Many of you guys told me that I needed to replace the master cylinder. Well today I took the car to the garage to have the master cylinder replaced & i still have the same problem.
Also when the pedal goes the whole way down my car starts to idle down really low as if it going to die.
What could be the problem ??
Old Apr 16, 2005 | 12:04 PM
JDM4DRACCORD's Avatar
Did you add rear disc brakes? Because the 95 Accord LX comes with drums in the rear and it does not have ABS. Just want to know ill look into your problem and let you know.
Old Apr 16, 2005 | 01:07 PM
kevinthefawker's Avatar
there might me some air in the system or its your master booser, where your brake master connects to
Old Apr 16, 2005 | 02:06 PM
RUBZERK's Avatar
Default Re: 5th gen Brake problem ---- Cont. (RUBZERK)
5th Gen Accords with ABS came with disc brakes on the rear from factory.
The master cylinder is on the booster.
Old Apr 16, 2005 | 11:07 PM
lv6l's Avatar
is there any leaks?
Old Apr 16, 2005 | 11:39 PM
Bay_707's Avatar
same problem i am having except my abs is unplugged, i havent tried to replace my master cylinder though. I also have an integra but it shouldnt matter much.
Old Apr 17, 2005 | 02:32 AM
The_Todd's Avatar
Farts in the shower
I would rebleed your brake system farthest away to closest. I would also make sure your MC and your booster are adjusted. Follow specifics in your haynes/chiltons/helms manual.
If this doesn't do the trick I would guess there is air in the system...check your connections and do basic diagnosis of the system; you're losing pressure somewhere.
Old Apr 17, 2005 | 05:01 AM
RUBZERK's Avatar
Default Re: 5th gen Brake problem ---- Cont. (.ken)
When bleeding the brakes, does the car have to be running ?
Old Apr 17, 2005 | 08:47 PM
RUBZERK's Avatar
[QUOTE=.ken]I would rebleed your brake system farthest away to closest. I would also make sure your MC and your booster are adjusted. QUOTE]
How do i adjust the booster ?
Old Apr 17, 2005 | 08:57 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">When bleeding the brakes, does the car have to be running ?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">How do i adjust the booster ?</TD></TR></TABLE>
Check your chiltons or repair manual for the details....I don't remember off hand.
Bizarre
Aug 19, 2008 04:18 PM
dadsvtechonda
Jun 29, 2007 05:03 PM
bstar22
Jan 12, 2007 03:29 PM
urbonjunk
Nov 28, 2006 06:23 PM
RUBZERK
Apr 11, 2005 11:33 PM
