Brake Problem
Old Jan 12, 2007 | 12:04 PM
bstar22's Avatar
Default Brake Problem
When my 2002 Accord 4cyl is started for the second or third time each day, the brakes lock up and cause the car to shudder violently. I replaced the front left caliper thinking that this was the problem. After this replacement, I noticed that all of the brakes were rubbing against the rotors as if I was lightly depressing the pedal.
If I stop the car for a few, the brakes return to normal and is fine for the remainder of the day. Each time I have tried to have the problem diagnosed, the brake tech states that he does not see any problem.
Any help?
Old Jan 12, 2007 | 03:29 PM
hondadude's Avatar
Default Re: Brake Problem (bstar22)
I've seen this problem of brakes dragging when some 'skippy lube' places dump P/S fluid in the brake master cylinder. The fluid warms up and expands.
The only other common cause I can think up is that the master cylinder could have been replaced and the push rod is not correctly adjusted.
Stance Movement
Jul 30, 2018 08:16 AM
namax
Jul 16, 2007 05:43 PM
urbonjunk
Nov 28, 2006 06:23 PM
D_TY3
Dec 11, 2005 05:41 PM
faiz_23
Jul 30, 2002 10:43 AM
