Car won't start, I'm at a loss
Old Apr 15, 2005 | 07:09 AM
funkfnamna's Avatar
Default Car won't start, I'm at a loss
ok I put a new starter in my car cause I thought the old one was bad but I was wrong. the engine wouldn't turn over and the starter would just click. the car was in storage for 6 months and I thought that maybe it was seized so I pulled the plugs out and dropped some oil on top of them and let it sit. Then when I tried to start it I could see the pistons moving slowly up and down so it's not locked up. I just don't know whats up. I double checked all the battery cables and they all have good connections. any ideas??
Old Apr 15, 2005 | 07:11 AM
IHateJDM's Avatar
Default Re: Car won't start, I'm at a loss (funkfnamna)
battery dead? alternator?
Old Apr 15, 2005 | 07:15 AM
pgpunkguy's Avatar
Default Re: Car won't start, I'm at a loss (IHateJDM)
distributor?
Old Apr 15, 2005 | 10:52 AM
funkfnamna's Avatar
the alternator or dizzy wouldn't stop it from turning over and the battery is fine
Old Apr 15, 2005 | 10:59 AM
IHateJDM's Avatar
can you take a wrench to the crank pulley bolt and turn the motor over by hand? I was under the impression that the starter didn't have the juice to turn it over.
Old Apr 15, 2005 | 11:38 AM
funkfnamna's Avatar
I tried 2 good starters, I'm thinking the rings are frozen and its just too hard to rotate for the starter.
Old Apr 15, 2005 | 11:40 AM
IHateJDM's Avatar
can you turn it by hand? and make sure you rotate the crank the same way it spins when it's running.
Old Apr 15, 2005 | 12:01 PM
B16aDasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funkfnamna &raquo;</TD></TR><TR><TD CLASS="quote">the alternator or dizzy wouldn't stop it from turning over and the battery is fine</TD></TR></TABLE>
Try push starting the car. When an FI car sits for a long time. alot of the fuel parts and sensors can get missed up.
Old Apr 15, 2005 | 12:04 PM
IHateJDM's Avatar
Default Re: Car won't start, I'm at a loss (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher &raquo;</TD></TR><TR><TD CLASS="quote">
Try push starting the car. When an FI car sits for a long time. alot of the fuel parts and sensors can get missed up.</TD></TR></TABLE>
is it boosted?
Old Apr 16, 2005 | 04:13 PM
funkfnamna's Avatar
well I'm pretty sure the rings were just frozen. I put some more oil in the cylinders, threw the plugs back in and let it sit overnight and she turned over great. thanks for the ideas guys
poprocksncoke
Jan 28, 2017 04:56 AM
JDMdb8isO
Feb 6, 2011 12:58 PM
bigandy90
Jan 2, 2008 09:35 PM
brzrkr
Nov 25, 2007 03:51 PM
ahcjar103
Dec 9, 2001 11:37 PM
