Car won't start, I'm at a loss
Old 04-15-2005, 07:09 AM
funkfnamna's Avatar
Default Car won't start, I'm at a loss
ok I put a new starter in my car cause I thought the old one was bad but I was wrong. the engine wouldn't turn over and the starter would just click. the car was in storage for 6 months and I thought that maybe it was seized so I pulled the plugs out and dropped some oil on top of them and let it sit. Then when I tried to start it I could see the pistons moving slowly up and down so it's not locked up. I just don't know whats up. I double checked all the battery cables and they all have good connections. any ideas??
Old 04-15-2005, 07:11 AM
IHateJDM's Avatar
Default Re: Car won't start, I'm at a loss (funkfnamna)
battery dead? alternator?
Old 04-15-2005, 07:15 AM
pgpunkguy's Avatar
Default Re: Car won't start, I'm at a loss (IHateJDM)
distributor?
Old 04-15-2005, 10:52 AM
funkfnamna's Avatar
the alternator or dizzy wouldn't stop it from turning over and the battery is fine
Old 04-15-2005, 10:59 AM
IHateJDM's Avatar
can you take a wrench to the crank pulley bolt and turn the motor over by hand? I was under the impression that the starter didn't have the juice to turn it over.
Old 04-15-2005, 11:38 AM
funkfnamna's Avatar
I tried 2 good starters, I'm thinking the rings are frozen and its just too hard to rotate for the starter.
Old 04-15-2005, 11:40 AM
IHateJDM's Avatar
can you turn it by hand? and make sure you rotate the crank the same way it spins when it's running.
Old 04-15-2005, 12:01 PM
B16aDasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funkfnamna &raquo;</TD></TR><TR><TD CLASS="quote">the alternator or dizzy wouldn't stop it from turning over and the battery is fine</TD></TR></TABLE>
Try push starting the car. When an FI car sits for a long time. alot of the fuel parts and sensors can get missed up.
Old 04-15-2005, 12:04 PM
IHateJDM's Avatar
Default Re: Car won't start, I'm at a loss (B16aDasher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher &raquo;</TD></TR><TR><TD CLASS="quote">
Try push starting the car. When an FI car sits for a long time. alot of the fuel parts and sensors can get missed up.</TD></TR></TABLE>
is it boosted?
Old 04-16-2005, 04:13 PM
funkfnamna's Avatar
well I'm pretty sure the rings were just frozen. I put some more oil in the cylinders, threw the plugs back in and let it sit overnight and she turned over great. thanks for the ideas guys
poprocksncoke
01-28-2017 04:56 AM
JDMdb8isO
02-06-2011 12:58 PM
bigandy90
01-02-2008 09:35 PM
brzrkr
11-25-2007 03:51 PM
ahcjar103
12-09-2001 11:37 PM
Quick Reply: Car won't start, I'm at a loss
