Need an opinion on why my motor sounds like its running on 3 cylinders
Old Apr 13, 2005 | 02:21 PM
kholmes's Avatar
Default Need an opinion on why my motor sounds like its running on 3 cylinders
Ok, I was driving today and I got on it bringing the rpm's to 7k or so and then all of a sudden the car started running real nasty like it was only 3 cylinders or sounding like a v8.
I checked compression, wires, plugs, distributer, ext. coil and all seems fine. The cam gears line up still at TDC. Vacuum lines seem good. My fuel pressure gauge shows a steady flow. Im running a obd1 h22a in a 98 civic. Any suggestions, ideas, or opinions will help. Thanx
Old Apr 13, 2005 | 02:58 PM
CXified's Avatar
Check to see if all of your injectors are working
Old Apr 14, 2005 | 04:38 AM
tommymoose's Avatar
Default Re: (CXified)
Check to see if there is spark in all 4 wires. With each wire, stick a screw driver in the boot and make contact with the metal in there. Then put the shaft of the screw driver close to a metal chasis point. Have somebody crank the motor and see if a spark jumps. If and when you find one wire thats spark doesnt jump, you've got the problem narrowed down alot.
Old Apr 14, 2005 | 07:01 AM
kholmes's Avatar
Default Re: (tommymoose)
Thanx guys, it actually turned out to be an injector thanx to a wire on the resistor box.
JDM B20 EH2
Jan 20, 2011 09:10 AM
LSVTEC408
Nov 8, 2007 03:33 PM
lsvtechatch92
Jun 25, 2007 03:03 PM
evilsolb16
12
Sep 6, 2004 09:11 PM
CrX1988Zc
Aug 23, 2002 06:22 AM
