ECU question
Old Apr 13, 2005 | 09:16 AM
zeroz's Avatar
Default ECU question
i heard from my tuner if i convert my OBD II to a OBD I and go hondata i won't pass emissions so i want to save myself the headache and was wondering would somthing like that will happend if i got the AEM EMS unit instead? any hlp would b great
Old Apr 13, 2005 | 09:42 AM
tgreaves's Avatar
Default Re: ECU question (zeroz)
Nope.. The obd2 cars have a interface port that the emissions place uses to check your car.. Any obd1 ecu isnt going to talk to that port..
Old Apr 13, 2005 | 01:53 PM
suckawillis's Avatar
Default Re: ECU question (tgreaves)
its a 10 min plug and play to change back to stock, so whats the problem?
Old Apr 13, 2005 | 04:38 PM
zeroz's Avatar
well im gonna go turbo so there's going to be all kinds of mods n tuning done to it and wouldn't putting in the stock ecu cause all sorts of chaos?
Old Apr 13, 2005 | 04:55 PM
zeroz's Avatar
anyone? feedback plz
Old Apr 13, 2005 | 08:55 PM
zeroz's Avatar
bump
Old Apr 14, 2005 | 05:53 AM
tgreaves's Avatar
Default Re: (zeroz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeroz &raquo;</TD></TR><TR><TD CLASS="quote">well im gonna go turbo so there's going to be all kinds of mods n tuning done to it and wouldn't putting in the stock ecu cause all sorts of chaos?</TD></TR></TABLE>
You can just swap out the ecu for the stock one and run through emissions.. I used to swap out the ecu in the parking lot of the testing center..
Old Apr 14, 2005 | 07:27 AM
JimBlake's Avatar
Default Re: (tgreaves)
After swapping the OBD-2 ECU back in, you have to drive around awhile. There's a couple readyness codes that have to be good, otherwise they'll fail you. Same thing if you try an ECU reset in the parking lot before the test...
But I guess that depends on how they run the test, & that's different in different states.
Old Apr 15, 2005 | 08:02 PM
zeroz's Avatar
hmm i see thxs
but would it throw up any cels? because theres going to b boost ?
Old Apr 16, 2005 | 10:30 AM
egsleepercivic's Avatar
unless all your turbo parts have carb #s I would assume you wouldn't pass a visual, if you have one in your state, you will probably have to take the turbo off to pass and get an obd2 ecu. don't know for surre though
JDmspoon22
18
Sep 4, 2007 09:09 AM
bravo831
Honda Civic (2001 - 2005)
11
Jan 20, 2007 08:59 AM
gsr_pimp88
Sep 9, 2006 05:19 AM
88hatchef
Oct 31, 2005 06:11 PM
tub_sephiroth
Nov 18, 2004 10:27 PM
