cam gears
Old Apr 9, 2005 | 05:39 PM
blkwidow420's Avatar
Default cam gears
Are Cam gears nessary with skunk 2 stage 2 cams. Or with any aftermarket cams. I know if tuned right they help but have the cams now and no money for gears but I want to install them now. will they work with stock cam gears?
please help.
Old Apr 9, 2005 | 05:42 PM
jackstands's Avatar
Default Re: cam gears (blkwidow420)
Stock cam gears will work. Most guys just want to dial in a little more whps. You only absolutely need them if you've milled the head, then you would need cam gears to properly degree your cams.
Old Apr 9, 2005 | 10:50 PM
PrettyLude's Avatar
i would get them, you can only adjust the stock ones so much
Old Apr 10, 2005 | 11:39 AM
DelSolDon's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i would get them, you can only adjust the stock ones so much</TD></TR></TABLE>
how would you adjust the stock ones?
Old Apr 11, 2005 | 05:19 PM
Default Re: (DelSolDon)
good question you can't
Old Apr 11, 2005 | 05:24 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">how would you adjust the stock ones?</TD></TR></TABLE>
Cut and weld?
If you don't have the money now, just get them later. They're not hard to install.
Old Apr 11, 2005 | 06:15 PM
Default Re: (drdisco69)
I have a portflow head do they mill the head? I don't know if they normaly mill it or not.
Old Apr 12, 2005 | 01:11 PM
Acura_I-RS's Avatar
bump for a homie
Old Apr 13, 2005 | 10:52 AM
LUCAS9277's Avatar
Default Re: cam gears (Acura_I-RS)
id get them to fine tune ur motor!
Old Apr 13, 2005 | 01:43 PM
suckawillis's Avatar
Default Re: cam gears (LUCAS9277)
get em, for sure!
Old Apr 13, 2005 | 04:44 PM
Default Re: cam gears (suckawillis)
SO are they nessary?
Old Apr 13, 2005 | 04:47 PM
I have a stock 1.8 ls head with 60000 miles for sale if intrested IM me
Also a stock b16 intake manifold
b16 injectors obd0 and fuel rail.
Brand New ARP MAIN STUD kit for a b16.
1.8 LS ECU unchipped.
2 B16 IAC valves obd1 and obd0
LS water pump with less than 8000 miles on it.
92-95 civic 2 door side skirts wings west poly
OBD1 ls ecu virgin
Best offer on all parts just IM me
Will also consider trades
LOOKING TO TRADER FOR B SERIES CAM GEARS
Old Apr 13, 2005 | 09:29 PM
ttt
Old Apr 14, 2005 | 01:37 AM
Green Lude 93's Avatar
you have already spent a pretty penny for those cams. you might as well complete them for another couple hundred bux with new cam gears. im sure there are plenty of used ones for sale in the classifieds.
btw.. your stock gears are fine.
B18C-YA!
Apr 4, 2006 04:06 PM
FaZetec
Jul 24, 2005 05:42 PM
vteec
Jun 23, 2004 12:30 AM
mrbsponge
May 30, 2004 06:15 PM
Try2Live4God
Jan 17, 2004 11:15 AM
