cam gears???
Re: cam gears??? (FaZetec)
If you need to tune, then it is ok. If you don't need to or don't plan on doing so in the future, then it won't do you any good.
-Shane
-Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaZetec »</TD></TR><TR><TD CLASS="quote">alright i appreciate it, well how about pulleys?</TD></TR></TABLE>
What about them? They won't mess up the cams if that's what your asking. They will give you a few hp *at most*. I haven't heard the greatest things about crank pulley's though. Unless it is lightened, it isn't that great for it.
-Shane
-Shane
Cam gears are only used to advance or retard your engine timing, in order to achieve tuning goals, without having to mess with your distributor's setting. Therefore, unless you are tuning your engine, they won't benefit you.
As far as pulleys go, alot of people buy them to reduce rotational mass, because most of them are made out of alumimun, but they won't affect your cams at all. Purely to reduce weight, and the gains made are small to say the least.
Steezn4NOReason
01-10-2005 07:50 PM
