higher compression.......
Old Jan 28, 2002 | 08:18 PM
dirtySOHC's's Avatar
Default higher compression.......
not too familiar with running higher compression pistons on a d16y8. who makes high comp pistons for y8's? if i was to build up my motor for high compression what would i need to consider being that i purchased stronger rods and bearings. fuel upgrade? head gasket?....??????
Old Jan 28, 2002 | 08:37 PM
976's Avatar
976
New User
Default Re: higher compression....... (SO[vtec]HC)
If you decided to upgrade you block internals, you might want to consider an out right swap - B16A. Cost and labor for resleving and upgrade of internals is way more than a swap. If you really want to work your y8 (props for doing BTW) I would search for some JE pistons, eagle rods and bearings. You wouldn't need a thinner head gasket, however it could raise compression upto .4 more. Of course fuel management would also need to be upgraded, but that's the cheap part, just a rail or reguartor - dyno to properly tune... Good luck.
Old Jan 28, 2002 | 08:38 PM
rainforest's Avatar
1. endyn, je, weisco non roller waved,
high compression make your car run leaner wich make higher combustion chamber temps so you need added fuel and a Little better cooling system like a radiator cap and thermostat will help.
Old Jan 28, 2002 | 08:44 PM
Default Re: higher compression....... (w00t!)
thanks man.....but i wanna see wat i can do with a N/A SOHC. the whole idea of a fast SOHC that is n/a is wat gets me going....
b00stedOne
Jul 28, 2014 09:56 AM
jmeyer99
Oct 24, 2010 10:32 AM
GSRerrr
Apr 4, 2005 07:11 PM
PSU-TEG
Aug 5, 2002 05:56 AM
