CAN'T GET LOWER BALL JOINT OFF!!
Old Apr 9, 2005 | 11:36 AM
allmotorEG-SI's Avatar
Default CAN'T GET LOWER BALL JOINT OFF!!
I have a balljoint seperator but its not working. Anyone have any ideas on how to get the lower ball joint off?
Old Apr 9, 2005 | 01:08 PM
got it! just had to use a bigger hammer. lol
Old Apr 9, 2005 | 01:52 PM
Redline130's Avatar
Default Re: (allmotorEG-SI)
The BFH never fails!
Old Apr 9, 2005 | 08:17 PM
nissanjon's Avatar
Default Re: (Redline130)
i had a ball joint that i could not get off. i had the separater fork damaged from all the hammering. finally i had to take a propane torch to heat up the lca and then 1 smack with the hammer and it popped right out.
Old Apr 9, 2005 | 10:28 PM
veganej's Avatar
beat the **** out of it.or spray a solvent in there to maybe loosen it up a bit first.
Old Apr 13, 2005 | 11:10 AM
LUCAS9277's Avatar
Default Re: (veganstraightedge)
bigger hammer alwayys works! lol
Old Apr 13, 2005 | 12:18 PM
PupaScoopa's Avatar
Default Re: (LUCAS9277)
No way! I swung a hammer for 15 minutes and couldn't bust my LCA ball joint out. This is an easy brains-vs-brawns trick...
Put a jack under the lca and raise it some. Slide an adjustable wrench or something in between the knuckle and CLA. Drop the jack and kick down on your brake rotor (castle nut loosened, don't remove it yet). A good kick or two will get it right out. You should break 0 sweat using this method.
Old Apr 13, 2005 | 03:28 PM
nissanjon's Avatar
Default Re: (PupaScoopa)
LMAO DAMN i wish i would have thought of that. i **** you not, i spent HOURS over a period of a couple weeks beating the **** out of my separator fork. i had to regrind my fork back into shape several times. i had to get new rotors, cuz after hours of swinging a hammer, you're bound to miss at least once
anyway, after talking to some real old school gear-heads, and after more than one of them suggesting a torch, i gave it a shot. fire will expand that LCA enough to pop the joint out. it worked, but i like the above idea much better.
Old Apr 13, 2005 | 04:03 PM
alpine_hikr's Avatar
Those separator forks often times damage the ball joint rather than help. If beating the **** out of it doesnt help, then try getting a long pry bar and wedge it imbetween the knuckle and lca. Pry on it and it will come out with no problems. If that still doesnt work then try an air hammer instead of a big *** hammer. Good luck
Old Apr 13, 2005 | 07:59 PM
Antilag's Avatar
Default Re: (alpine_hikr)
boy that is crazy . All i do, let say were removing the passenger side lower ball joint. turn the wheel all the way to the right. get a jack and place it under the rotor and jack it up high, remove the castle nut. smack the lca where the ball joint is, a big hammer should bust it loose after the 2-3 hit. i've down dozens like that with success and no damage.
Old Apr 13, 2005 | 10:37 PM
yeah i tore the damn thing rigght in half. no more bushing any more... oh well.
Old Apr 14, 2005 | 08:02 AM
nissanjon's Avatar
yup - definitely have to replace the rubber boots after using the fork.
Old Apr 14, 2005 | 09:29 AM
Crazydave's Avatar
Default Re: (nissanjon)
using the forks suck,
I have always used a BFH, and it has always worked eventually,
sometimes i had to use a Big F#$king Guy with my BFH.
I guess I wasn't hitting it hard enough, but once you flatten your finger once on a spindle, you tend to be little wussier the next time you swing a hammer
Old Apr 14, 2005 | 10:21 AM
Antilag's Avatar
Default Re: (Crazydave)
big f#$*&ing guy? LOL
Old Apr 14, 2005 | 11:52 AM
CRXified's Avatar
Default Re: (9sech22civic)
haha i took mine off the ohter day when i took my d15 powerplant out and both the ball joints came right off, no hammering or nothing, just lifted them off...... is this bad? they are new last year...
Old Apr 14, 2005 | 02:02 PM
My accord did the same thing, I dont think that is right, but oh well.
Old Apr 15, 2005 | 01:34 AM
littledan's Avatar
here is a trick you can try. jack up the whole suspension from the lca. wedge a wrench in between the knuckle and the lca. remove the jack. then kick the suspension downward and the wrench will pop the ball joint off. try it out!
... and if that doesn't work a bfh works for everything
Old Apr 15, 2005 | 09:05 AM
CRXified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpine_hikr &raquo;</TD></TR><TR><TD CLASS="quote">My accord did the same thing, I dont think that is right, but oh well.</TD></TR></TABLE>
u mean the same thing happened to urs, they came right off? anybody know y or if this is ok? or maybe its cause they are new...
Old Apr 15, 2005 | 09:23 AM
nissanjon's Avatar
Default Re: (CRXified)
lucky
Old Apr 15, 2005 | 11:01 AM
CRXified's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nissanjon &raquo;</TD></TR><TR><TD CLASS="quote">lucky </TD></TR></TABLE>
haha i was wondering if its safe is all
Old Apr 15, 2005 | 07:24 PM
Yeah but my ball joints were original...lol I may need to replace those.
Old Apr 15, 2005 | 10:08 PM
Lord Helmet's Avatar
https://honda-tech.com/zerothread?id=887859 For people who still don't know.
Old Apr 16, 2005 | 10:26 AM
egsleepercivic's Avatar
^doesn't get any easier than the craftsman rachett trick ^
Old Apr 16, 2005 | 07:59 PM
CRXified's Avatar
Default Re: (egsleepercivic)
dones anybody have any suggestions as to y my bal joint seperated so easily, or were already seperated?
Old Apr 17, 2005 | 05:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">dones anybody have any suggestions as to y my bal joint seperated so easily, or were already seperated?</TD></TR></TABLE>
that's what they are suppose to do when you remove them. not stuck in the LCA.
oranginal
Jul 28, 2010 05:53 AM
Chiller
Mar 29, 2005 03:23 PM
ultraforce77
Jul 15, 2004 02:59 PM
2camsaam
Oct 2, 2003 07:30 AM
2camsaam
21
Oct 1, 2003 07:32 PM
