msd ignition install question
Old Apr 9, 2005 | 03:45 AM
Green Lude 93's Avatar
Default msd ignition install question
i got the msd 6a from my friend and i dont know where to connect the green, purple and white wire?
Old Apr 9, 2005 | 06:11 AM
EE_Chris's Avatar
Default Re: msd ignition install question (Green Lude 93)
Did you bother checking MSD's website to see if they had a .pdf manual for the 6A?
Did you bother searching here for it? If yes, did you see how a common trend was that if you're making less than 350whp, it really isn't a worthwhile mod? Did you also see the numerous threads pertaining to burning out stock ignition components when using the 6A?
Even if you got it for free, its not worth the headaches it causes unless you're making some power. I know a few people who try and daily drive with these things only to burn out ICM's and coils - and that gets pricey replacing those items.
Old Apr 9, 2005 | 04:46 PM
Default Re: msd ignition install question (EE_Chris)
as a matter of fact i have researched it and i decided not to do this but since i got it for free and i am giong to have more than 350hp so i might as well do it. i also searched for instructions on this site and came up empty handed. i did look at the instructions and it didnt mention if i should hook up the white wire or the purple and green one. it just showed me how to hook it up. as we speak my motor is getting a fully built head and built bottom. i just bought some 850cc injectors to put in and i have a custom turbo kit. i dont daily drive my car anyways.
Old Apr 9, 2005 | 05:08 PM
EE_Chris's Avatar
General 6 series manual
Honda specific diagram
Good research.
You don't use the purple/green wires because as the manual states, and as your research showed you, these wires are for a magnetic pickup or crank trigger. The white wire is the wire you use because you have an electronic ignition.
swapped95
12
Dec 29, 2006 12:38 PM
H22a4u
Jun 11, 2005 07:23 PM
civic ex si
Mar 26, 2003 02:57 PM
Phat_GSR
Aug 30, 2002 09:50 PM
