no spark!
Old Jan 28, 2002 | 12:34 PM
johnzm's Avatar
Default no spark!
i went and just got done doing a compression test, the #2 plug wire came apart on the plug, and since i ddint have anything to pull it out with i tested the other three. i got over 200for all of them. i put it back together, and no spark! my cars dead, and i pulled a plug and it smells like theres gas geting to it, but when i turn it over theres no spark. i pulled the cap and rotor off, and everything *looks* fine but i need to know which wires to look for a signal on. BTW its a b16
Old Jan 28, 2002 | 01:03 PM
mercury's Avatar
New User
Default Re: no spark! (johnzm)
If you didn't unplug the ECU fuse or disable the ignition system in some other way, you've probably blown your ignition coil and ignitor. Those two items should be <$250 from the dealer.
Old Jan 28, 2002 | 01:42 PM
Gennady's Avatar
New User
Try reseting the ECU.
Old Jan 28, 2002 | 03:06 PM
johnzm's Avatar
Default Re: no spark! (mercury)
i got the cap off and im testing wires ... i got a solid light on the black/yellow stripe (thi is inside the cap) and the other wire that goes to the ign coil (yellow/green stripe) gives me a solid light when acc is on and when turned over flashes . so the coil is bad, right? i dindt get a signal out of the coil : / ok i just ran uot and with the coil out and unplugged, it gives me no signal on the yellow/green but a steady light on the black yellow with the coil unplugged. is the module bad or just the coil?
cody1234
Nov 30, 2012 05:34 AM
JDM_EK4_Coupe
Apr 10, 2007 06:05 AM
TehMan
Feb 17, 2006 11:18 AM
vtec.dc2
Jan 20, 2006 04:49 PM
Yambor
Jul 30, 2004 06:55 AM
