is a 17-18 a/f too lean at idle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">14.7-15.1 is where you want to be</TD></TR></TABLE>
Idle's usually become unstable leaner than 16AFR. However it wont hurt anything if you can maintain a steady and stable rpm.
*Edit: Make sure your wideband is calibrated!
disconnect the bosch sensor. should stabilize around 14.6 to 14.7. thats about the only thing I am aware of to check the calibration. Things I have noticed that the PLX wideband isnt so accurate at idle. I think its the very low velocity of the exhaust coming off the valves that cause the issues. Mine jumps from like 14.5-16 consistantly but if I rev it to 1000 RPM or higher it stabilizes in a shorter range.
Ri5e
Dec 31, 2004 01:48 AM
And it idled like crap obviously.
