Popping in idle
Old Jan 13, 2006 | 09:57 PM
tianporn's Avatar
Default Popping in idle
Hey just did my B18c swap. It runs all good and timing is set and running P72 map. The problem is in idle the car will idle perfect but once in a while 'pop' like backfire and then idle good again until a few seconds later when it pops again. Car drives fine with no misfiring or hesitation. What could the problem be? Could it be it running rich at idle or something to do with the ignition system?
Thanks
Old Jan 14, 2006 | 08:23 AM
ILoveJDM.'s Avatar
Sounds like its missing...
Old Jan 14, 2006 | 04:14 PM
tianporn's Avatar
Default Re: (ILoveJDM.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILoveJDM. &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like its missing...</TD></TR></TABLE>
If its missing wouldnt it happen other places in the rev range? Only pops on idle and i've had a look at the plugs and they aren't fouled.
Old Jan 14, 2006 | 07:55 PM
rainforest's Avatar
Default Re: (tianporn)
i would try to get a wideband and datalog you a/f ratio at idle becasue you could be running either lean or rich to have a stumble at idle. most likely a lean condition i noticed that most base maps are lean at idle.
Old Jan 16, 2006 | 12:48 AM
tianporn's Avatar
Default Re: (rainforest)
Dont have access to a wideband though. Will check plugs again soon
Old Jan 16, 2006 | 02:37 AM
rainforest's Avatar
yeah i know sometime its easy for someone to say buy this and that like i did but just letting you know. checking the plugs will be the best way to check for you.
Old Jan 21, 2006 | 04:06 AM
tianporn's Avatar
Default Re: Popping in idle (tianporn)
Bump still happening. Could it be symptoms of the dizzy about to crap out?
ncsi
Jan 3, 2012 03:08 PM
xotic_crx
Dec 11, 2006 09:40 PM
turboB16RFD
Oct 9, 2005 09:15 PM
Hyaboosta
Jul 13, 2005 02:14 PM
tinkerbell
Jan 28, 2002 06:12 PM
