Sleeve Scratches?
Old Apr 5, 2005 | 03:22 PM
Targa4Life's Avatar
Default Sleeve Scratches?
Ok so im in the middle of an engine rebuild and I have just gotten the sleeves honed out (stock b18b block with stock sleeves) and I noticed that there are some mild scratches in each cilynder. I was wondering what I should do about it. I dont want to put the engine back together and crack a sleeve or anything so im wondering what do. Should I get it bored, re-sleeved, or should I just forget about it? The scratches are big enough to catch your fingernail but they are not splits.....yet anyway. Im running an ls/vtec with 8psi of boost. I dont "Want" to spend the money on sleeving with darton sleeves or anything but I refuse to run an unreliable engine. What should I do?
Old Apr 5, 2005 | 03:25 PM
STHPERFORMANCE's Avatar
Default Re: Sleeve Scratches? (Targa4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life &raquo;</TD></TR><TR><TD CLASS="quote">The scratches are big enough to catch your fingernail</TD></TR></TABLE>
Have it bored over.
Old Apr 5, 2005 | 03:43 PM
dustin's Avatar
Hmm I wouldn't run the block like that. try to go to 81.5mm.
Old Apr 5, 2005 | 03:55 PM
Targa4Life's Avatar
Would boring stock sleeves make the sleeves too thin? Could'nt they crack anyway?
Old Apr 5, 2005 | 03:57 PM
dustin's Avatar
They could. Resleeving is the best idea. But at 8psi you will be fine with 81.5mm with decent tuning.
Old Apr 5, 2005 | 04:03 PM
Targa4Life's Avatar
Default Re: Sleeve Scratches? (dustin)
.......Ok so this is obviosly a dumbass question but. What is the stock bore on a B18B? And I have already dished out a pile of money in tuning would it really be nessesary to do again if I go with 81.5mm?
Old Apr 5, 2005 | 04:04 PM
dustin's Avatar
81mm is stock bore. 3.189"
Old Apr 5, 2005 | 04:06 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life &raquo;</TD></TR><TR><TD CLASS="quote">.......Ok so this is obviosly a dumbass question but. What is the stock bore on a B18B? And I have already dished out a pile of money in tuning would it really be nessesary to do again if I go with 81.5mm? </TD></TR></TABLE>
It might be cheaper to buy a clean ls block for like $100 dude
Old Apr 5, 2005 | 04:08 PM
Targa4Life's Avatar
Where im to.... there are no $100 ls blocks. I might be able to get one for $1000 and thats going to used with probably 80,000kms on it.
dustin's Avatar
Hmm usually you can get a stripped LS block (no crank) for cheap... ask around.
Old Apr 5, 2005 | 04:11 PM
SPOOLINmatt's Avatar
we run 20 psi and 447 daily on stock sleeves at 81mm. 81.5mm isnt gonna make much of a difference. now 82-84mm, especailly 84mm and that **** can be kissed goodbye. im building an 81.5mm ls vtec turbo, 20psi should be my friend just as well. of course ill run 12-13psi everyday.
Old Apr 5, 2005 | 04:21 PM
Targa4Life's Avatar
Default Re: Sleeve Scratches? (SP00LIN)
WTF? 20psi on stock sleeves, What kind of pistons and rods do you use? How long have you been running your engine like that? Wow. My freind blew his sleeves at 15psi? whats on the go? I still dont know what to do about my engine though. I mean, would the scratches turn into cracks?
Old Apr 5, 2005 | 04:22 PM
dustin's Avatar
I've seen 30psi on stock sleeves... it's all tuning. Not stock bottom end, of course.
Old Apr 5, 2005 | 04:46 PM
Targa4Life's Avatar
!!!! I guess ya learn something everyday......... So If bored to 81.5mm I should be fine. I have a good tune (as far as I know). Also, do I need to get beggier pistons if I do that?
Old Apr 5, 2005 | 04:49 PM
dustin's Avatar
Bigger bore -&gt; bigger pistons
Yes you need 81.5mm pistons to run 81.5 mm bore.
Old Apr 5, 2005 | 04:53 PM
Targa4Life's Avatar
hmm What is the best place to get these?
Old Apr 5, 2005 | 04:55 PM
dustin's Avatar
Pistons? Check here
https://honda-tech.com/zeroforum?id=49
Old Apr 5, 2005 | 04:59 PM
Thurman Merman's Avatar
honda/acura make oversized stock pistons correct? if so, is the only difference between stock and aftermarket oversized pistons going to be forged and one not?
Old Apr 5, 2005 | 05:00 PM
dustin's Avatar
Default Re: Sleeve Scratches? (Thurman Merman)
yep you can get OE pistons in 81.5mm.
Aftermarket pistons are (usually) forged and can be had in different compression ratios. They also usually have floating wrist-pins as opposed to press-in wrist pins on the OE rod/piston setup.
Old Apr 5, 2005 | 05:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">yep you can get OE pistons in 81.5mm.</TD></TR></TABLE>
i knew subarus do (parts dept. lol), but wasn't 100% sure of the hondas
Old Apr 5, 2005 | 05:18 PM
Targa4Life's Avatar
are floating pins better than press in ones? What are the disadvantages/advantages?
Old Apr 5, 2005 | 05:20 PM
dustin's Avatar
it's a lot easier to swap/install pistons w/ a floating wrist pin. You don't need a machine shop to press the wrist pins out... you can just remove/install the clips yourself.
Old Apr 5, 2005 | 07:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life &raquo;</TD></TR><TR><TD CLASS="quote">WTF? 20psi on stock sleeves, What kind of pistons and rods do you use? How long have you been running your engine like that? Wow. My freind blew his sleeves at 15psi? whats on the go? I still dont know what to do about my engine though. I mean, would the scratches turn into cracks?</TD></TR></TABLE>
its been over a year, the rings are starting to go, but he really gives it hell every single day at full boost. its tuned really well with hondata. mine will be uberdata. a lot of people on here sleeve their stuff for 300whp, what a waste.
Old Apr 5, 2005 | 07:52 PM
nfn15037's Avatar
FWIW OEM pistons only come in 81.25, aftermarkets come in 81.5mm and a plethora of other sizes.
Old Apr 7, 2005 | 08:57 AM
Targa4Life's Avatar
Default Re: Sleeve Scratches? (nfn15037)
well. I have the new 81.5mm piston and rings in my hands, now off to the machine shop..... again!
mightymaxgst
Oct 29, 2008 07:02 AM
JDean6pac
Apr 8, 2007 04:23 PM
hondachris1994
Mar 24, 2006 04:21 AM
spoon23_JDizM AkA SpOoN20
Dec 7, 2004 03:43 AM
pane93civhb
Oct 25, 2004 04:26 AM
