Sleeve Scratches?
Ok so im in the middle of an engine rebuild and I have just gotten the sleeves honed out (stock b18b block with stock sleeves) and I noticed that there are some mild scratches in each cilynder. I was wondering what I should do about it. I dont want to put the engine back together and crack a sleeve or anything so im wondering what do. Should I get it bored, re-sleeved, or should I just forget about it? The scratches are big enough to catch your fingernail but they are not splits.....yet anyway. Im running an ls/vtec with 8psi of boost. I dont "Want" to spend the money on sleeving with darton sleeves or anything but I refuse to run an unreliable engine. What should I do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life »</TD></TR><TR><TD CLASS="quote">The scratches are big enough to catch your fingernail</TD></TR></TABLE>
Have it bored over.
Have it bored over.
.......Ok so this is obviosly a dumbass question but. What is the stock bore on a B18B? And I have already dished out a pile of money in tuning would it really be nessesary to do again if I go with 81.5mm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life »</TD></TR><TR><TD CLASS="quote">.......Ok so this is obviosly a dumbass question but. What is the stock bore on a B18B? And I have already dished out a pile of money in tuning would it really be nessesary to do again if I go with 81.5mm?
It might be cheaper to buy a clean ls block for like $100 dude
</TD></TR></TABLE>It might be cheaper to buy a clean ls block for like $100 dude
Where im to.... there are no $100 ls blocks. I might be able to get one for $1000 and thats going to used with probably 80,000kms on it.
we run 20 psi and 447 daily on stock sleeves at 81mm. 81.5mm isnt gonna make much of a difference. now 82-84mm, especailly 84mm and that **** can be kissed goodbye. im building an 81.5mm ls vtec turbo, 20psi should be my friend just as well. of course ill run 12-13psi everyday.
WTF? 20psi on stock sleeves, What kind of pistons and rods do you use? How long have you been running your engine like that? Wow. My freind blew his sleeves at 15psi? whats on the go? I still dont know what to do about my engine though. I mean, would the scratches turn into cracks?
!!!! I guess ya learn something everyday......... So If bored to 81.5mm I should be fine. I have a good tune (as far as I know). Also, do I need to get beggier pistons if I do that?
yep you can get OE pistons in 81.5mm.
Aftermarket pistons are (usually) forged and can be had in different compression ratios. They also usually have floating wrist-pins as opposed to press-in wrist pins on the OE rod/piston setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">yep you can get OE pistons in 81.5mm.</TD></TR></TABLE>
i knew subarus do (parts dept. lol), but wasn't 100% sure of the hondas
it's a lot easier to swap/install pistons w/ a floating wrist pin. You don't need a machine shop to press the wrist pins out... you can just remove/install the clips yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life »</TD></TR><TR><TD CLASS="quote">WTF? 20psi on stock sleeves, What kind of pistons and rods do you use? How long have you been running your engine like that? Wow. My freind blew his sleeves at 15psi? whats on the go? I still dont know what to do about my engine though. I mean, would the scratches turn into cracks?</TD></TR></TABLE>
its been over a year, the rings are starting to go, but he really gives it hell every single day at full boost. its tuned really well with hondata. mine will be uberdata. a lot of people on here sleeve their stuff for 300whp, what a waste.
spoon23_JDizM AkA SpOoN20
Dec 7, 2004 03:43 AM
pane93civhb
Oct 25, 2004 04:26 AM
