Turbo is leaking oil from DP
Old Apr 5, 2005 | 02:35 PM
dturbo's Avatar
Default Turbo is leaking oil from DP
I just installed a t3 turbo that a buddy gave me to use and when i went to start it up, after about 2-3 minutes oil started dripping like crazy out of the DP side. Checked drain line for kinks and no kinks. What caused this and is the turbo shot?
Old Apr 5, 2005 | 02:40 PM
dustin's Avatar
Default Re: Turbo is leaking oil from DP (flyazzcivic)
Junk turbo or blocked return line (which you already checked)
Old Apr 5, 2005 | 02:47 PM
SHystrdyGSRtdy's Avatar
Default Re: Turbo is leaking oil from DP (dustin)
check your turbo seals?
Old Apr 5, 2005 | 02:50 PM
dturbo's Avatar
Cant be the return line, completly took off the return line so oil can drip into a pan and it was draining fine and oil still came out of DP side.
Will a rebuild kit fix this?
Old Apr 5, 2005 | 02:51 PM
dustin's Avatar
Maybe but you have to have the turbo balanced after taking the wheels off.
Might be cheaper to just buy something like this:
http://store.yahoo.com/cheaptu....html
Old Apr 5, 2005 | 03:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyazzcivic &raquo;</TD></TR><TR><TD CLASS="quote">Cant be the return line, completly took off the return line so oil can drip into a pan and it was draining fine and oil still came out of DP side.
Will a rebuild kit fix this?</TD></TR></TABLE>
if for sure that is your problem.. you can send in your turbo to have it rebuilt.. (same website dustin sent you)
"00"R
Jun 21, 2007 10:48 AM
bboyfreeze
Apr 2, 2007 08:38 PM
slo_crx
Oct 12, 2004 05:51 PM
alfee
Jul 30, 2004 02:42 PM
Elite Hatch
Oct 20, 2002 05:43 AM
