BOV problems
Old Apr 5, 2005 | 02:13 PM
MAFDARK's Avatar
Default BOV problems
ok, when i shift...all i hear is flutter (like a rattle snake). but i dont know what exactly its comeing from...because when i rev the car in neutral the wastegate flutters (why is this???).
i dont know whats wrong. i loosened the screw on the valve so much, now i am loosing vacume at idle.
what the hell is going on!
Old Apr 5, 2005 | 02:22 PM
EJ1 wilcox's Avatar
Default Re: BOV problems (MAFDARK)
I don't understand what you are asking... your BOV flutters when you shift? Sounds like it's working correctly...
Your wastegate flutters when you rev the car in neutral? Your wastegate shouldn't move when you are not driving...
What BOV do you have? And, what does it have to do with your wastegate?
Old Apr 5, 2005 | 02:24 PM
dustin's Avatar
Is it the turboxs? Might need to fool with the washers...
Old Apr 5, 2005 | 02:25 PM
MAFDARK's Avatar
i had originally thought that my BOV flutters...now i think that my wastegate is and not my BOV.
so i want to know why my BOV isnt working right, and why my wastegate might flutter.
also...should my BOV be open or shut during idle?
edit: it is a cheap ebay one. nothing name brand.
Old Apr 5, 2005 | 02:31 PM
dustin's Avatar
Default Re: (MAFDARK)
Wastegates don't flutter. What in the last 12 minutes changed your mind?
Revving the car in neutral can make the BOV make noise... depends on the BOV.
I can't see how loosening your BOV screw can make you loose vacuum at idle though... unless there is something wrong with the BOV.
Old Apr 5, 2005 | 02:35 PM
MAFDARK's Avatar
i just checked it out and your right, the BOV wont loose vac at idle...
but the wastegate is fluttering. which now im really stumped because i took off the vac. hose from it and plugged it....still a flutter.
Old Apr 5, 2005 | 02:36 PM
EJ1 wilcox's Avatar
What kind of wastegate do you have? Which vacuum source do you have it hooked up to?
Old Apr 5, 2005 | 02:39 PM
MAFDARK's Avatar
at first i had it hooked up to one on the intake manifold, and then i tried the source with the valve on it up at the fire wall.
the 2nd one is what i normally have the wastegate hooked up to, but i was trying to test everything out.
the turbo has an internal wastegate. its a garrett T25 normally found on a 300Z
Old Apr 5, 2005 | 02:42 PM
MAFDARK's Avatar
i think i got the BOV fixed just by playing around with it, i will have to drive it alittle more to adjust it. now i just need to find out how to shut up the wastegate.
Old Apr 5, 2005 | 02:55 PM
dustin's Avatar
The wastegate shouldn't make any noise at all. Is the WG exit internal to your exhaust or do you have a separate "dump tube"? If it's internal, the WG should never make noise...even at full boost.
Old Apr 5, 2005 | 02:56 PM
MAFDARK's Avatar
its internal....and it only makes noise when i let off throttle /shift.
im soo stumped
Old Apr 5, 2005 | 03:02 PM
dustin's Avatar
BOV = makes noise when you shift
wastegate = controls boost pressure by rerouting exhaust, not supposed to make noise
Old Apr 5, 2005 | 03:08 PM
IHaveTurbos's Avatar
Default Re: (dustin)
Sounds like your BOV is not opening and your hearing the compressor surge that is the only fluttering sound I can think of from the turbo.
Old Apr 5, 2005 | 03:17 PM
MAFDARK's Avatar
i think your right....im working on it. i dont know if i can open up the BOV any more
Old Apr 5, 2005 | 03:33 PM
dustin's Avatar
where do you have the BOV tapped (the pressure signal)...?
Old Apr 5, 2005 | 03:53 PM
MAFDARK's Avatar
im not quite sure what you mean.
but i did get the BOV loose enough to open up when i shift. this made the flutter stop so i am assuming it was actually turbo chatter
Old Apr 5, 2005 | 03:54 PM
hotaccord243's Avatar
haha i think me and you are having the same trouble
92 CIVIC HATCH VX
Feb 27, 2006 04:53 PM
safe driver
May 1, 2002 02:44 PM
