o-ringed block and cometic head gasket?
any golden eagle block o- ringed or not cannot use that gasket...They are step decked and the head will not sit flat against the block. it will not seal and mix coolant.
I wouldnt use that gasket on any step decked or oringed block..its goinng to **** **** up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote">Thought you had to run a copper w/o-ringed block ?</TD></TR></TABLE>
That's what I thought too, something like this:
http://www.scegaskets.com/products/titan.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">Make sure you use the Cometic HP gasket, I blow out the regular Cometic MLS gasket in a month, but the HP version will last a couple of years.</TD></TR></TABLE>
If your block is step decked DO NOT RUN THAT GASKET...I ran a regular cometic on a step decked golden eagle block and it held fine on 20 psi daily with an sc61...
tourque it to 79 ft lbs and your golden
(80 ft lbs with orings)
dantamparacer
Apr 17, 2012 07:37 PM
hondafanatic1
Feb 19, 2004 05:35 AM
