o-ringed block and cometic head gasket?
Old Apr 4, 2005 | 12:08 PM
WREKONIZE V8 KLR's Avatar
Default o-ringed block and cometic head gasket?
can i use a cometic head gasket with a fire wire on an o-ringed block, or do i need to run an oem hg?
Old Apr 4, 2005 | 07:10 PM
PrettyLude's Avatar
you need the regular mls gasket, without the o-ring in the gasket, you can't use the one with the o-ring or fire ring in it
Old Apr 4, 2005 | 07:11 PM
SOHCmaster's Avatar
Thought you had to run a copper w/o-ringed block ?
Old Apr 5, 2005 | 01:11 AM
D@nnY's Avatar
any golden eagle block o- ringed or not cannot use that gasket...They are step decked and the head will not sit flat against the block. it will not seal and mix coolant.
I wouldnt use that gasket on any step decked or oringed block..its goinng to **** **** up
Old Apr 5, 2005 | 06:13 AM
rmcdaniels's Avatar
Default Re: (PK SPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED &raquo;</TD></TR><TR><TD CLASS="quote">Thought you had to run a copper w/o-ringed block ?</TD></TR></TABLE>
That's what I thought too, something like this:
http://www.scegaskets.com/products/titan.html
Old Apr 5, 2005 | 08:40 AM
Default Re: (rmcdaniels)
thanks guys goiong with a titan now
Old Apr 5, 2005 | 12:45 PM
Default Re: o-ringed block and cometic head gasket? (WREKONIZE V8 KLR)
actually i think i am gonna pass on the o-ringing of the block and try out the cometic hg. hope it holds
Old Apr 5, 2005 | 03:42 PM
rmcdaniels's Avatar
Make sure you use the Cometic HP gasket, I blow out the regular Cometic MLS gasket in a month, but the HP version will last a couple of years.
Old Apr 5, 2005 | 10:13 PM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you use the Cometic HP gasket, I blow out the regular Cometic MLS gasket in a month, but the HP version will last a couple of years.</TD></TR></TABLE>
If your block is step decked DO NOT RUN THAT GASKET...I ran a regular cometic on a step decked golden eagle block and it held fine on 20 psi daily with an sc61...
tourque it to 79 ft lbs and your golden (80 ft lbs with orings)
Old Apr 6, 2005 | 10:40 AM
Default Re: (D@nnY)
its not stepped decked what do you recommed on trq? with hp cometic hg fire wire
dantamparacer
Apr 17, 2012 07:37 PM
grand champ
Sep 29, 2010 08:59 PM
92HB_HB
Sep 12, 2005 09:28 PM
hondafanatic1
Feb 19, 2004 05:35 AM
d mafia
Mar 27, 2002 11:30 AM
