changing my timing belt..take out engine?
Old Apr 4, 2005 | 04:38 AM
motormanSR's Avatar
Default changing my timing belt..take out engine?
here's the story.. i have to change all 4 mounts on my accord..my t-belt is due.. it is woth taking out the engine to do since i have to change all 4 mounts?
second question... gatorback (goodyear) is supposed to be a pretty good brand. they are allot cheaper than the dealer think i should go with those?
3rd question...is the belt from the dealer actually made by honda? for example if you buy a starter from a dealer i they sell a DENSO.....
thanks in advance guys..lookign to do this job this weekend
Old Apr 4, 2005 | 05:45 AM
v4lu3s's Avatar
RTFM
if you really want to take the engine out go for it, but i havent ever see it worhwhile to take the axles out, disconnect electrical, fuel lines etc jsut to do mounts and a timing belt. it would add quite a bit of work though the rear mount is a bitch to do with the engine in the car.
goodyear gatorbacks are decent wet perofrmance tires. i think they used to use them a lot for race cars on wet tracks.
not sure who makes the belts for honda, but honda makes very few parts of their own (just like every car manufacturer), Most parts are made by someone else ot Honda specs.
Old Apr 4, 2005 | 06:49 AM
Turbowa's Avatar
Default Re: changing my timing belt..take out engine? (motormanSR)
Ok here we go:
1: You don't need to take out the engine. Thats a lot of extra work. You can do all the mounts with the engine still in the car.
2: As for belt. I would only use a Honda belt. Its made by Gates. I wouldnt trust a goodyear belt on my lawn mower.
And that denso starter your talking about is kind of a honda. Denso is owend by honda.
Old Apr 4, 2005 | 06:56 AM
THEROPE's Avatar
Default Re: changing my timing belt..take out engine? (Turbowa)
if you look just about everything is made by denso on a honda car
Old Apr 4, 2005 | 08:01 AM
trinitymotors's Avatar
per recent experience, replace the tensioner along with the timing belt
Old Apr 4, 2005 | 08:31 AM
kniob's Avatar
Default Re: changing my timing belt..take out engine? (THEROPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEROPE &raquo;</TD></TR><TR><TD CLASS="quote">if you look just about everything is made by denso on a honda car</TD></TR></TABLE>
denso, toyo, and stanely and that one company that sounds like mitsubishi but isn't... mitsusoyo or something, I completely forget now.
Old Apr 5, 2005 | 06:56 PM
Schmitey's Avatar
Default Re: changing my timing belt..take out engine? (kniob)
I like gaterback belts, they are the only ones I've seen that have a copper core versus polyester which can wear out and break, but that's just me. That and I know people that work for Goodyear and get me the hookup...free tensioner too! Definitely leave the engine in there man. You'll have to block it up but you'll realize what a crazy idea that was when you get in there!
Old Apr 6, 2005 | 08:08 AM
motormanSR's Avatar
Default Re: changing my timing belt..take out engine? (Schmitey)
free tensioner!!!!...where can i get that hook up? i thought about it and i decided that i will be leaving the motor in. where is a good place to buy one (besides the obvious..dealer) ?
Old Apr 6, 2005 | 09:14 AM
flight50's Avatar
just my 2 cents. if you are going change the timing belt, change the water pump as well if it hasn't been done. you'll wish you had if you have to take the engine out again for the water pump when you could have done it when you changed the belt.
Old Apr 6, 2005 | 09:56 AM
-RedneckDave-'s Avatar
Working
Default Re: changing my timing belt..take out engine? (flight50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flight50 &raquo;</TD></TR><TR><TD CLASS="quote">just my 2 cents. if you are going change the timing belt, change the water pump as well if it hasn't been done. you'll wish you had if you have to take the engine out again for the water pump when you could have done it when you changed the belt.</TD></TR></TABLE>
I agree with you on this. while you are in there you might as well do the water pump because it is a good preventative maintenance and it is worth it in the long run.
Old Apr 6, 2005 | 10:02 AM
Schmitey's Avatar
Default Re: changing my timing belt..take out engine? (-RedneckDave-)
i know people that work at the goodyear plant in Lincoln, NE...but I don't live there anymore
and if you take the engine out to change the water pump you are a moron!
Old Apr 6, 2005 | 10:34 AM
flight50's Avatar
Hmm how polite. He spoke noting of a water pump. I brung up the fact that if he takes out the engine period, don't just do the mounts and the timing belt. Make sure the water pump is included in the process.
Old Apr 6, 2005 | 02:34 PM
Schmitey's Avatar
the way you worded it made it sound like you'd take the engine out to do the waterpump...and regardless if you do a timing belt job change the water pump
Old Apr 7, 2005 | 03:22 AM
motormanSR's Avatar
dudes....i had already bought the water pump ..there was no question about that... btw ..the engine is staying in... i got a good deal on a tensioner set yesterday so those are being changed as well
Electron Man
Aug 15, 2013 01:10 PM
BlackFlame11
Apr 2, 2013 06:55 AM
SinsEvil666
16
Jul 22, 2009 05:51 AM
delanok
May 20, 2008 08:20 AM
peja43916
Nov 3, 2005 05:53 PM
