Tran slip...
Re: Tran slip...
Mine did the same. Check the engine mounts. One on front, one on left and right, and one on the rear. Four total. I thought mine was broke. Turns out the attachment point of the mount on the engine was broke off and someone literally glued it back on. You most likely won't have that problem. None of the mounts are more than $100. And if it's your driver side mount, go ahead and change your timing belt at the same time. Let me know. Hope this helps dude.
Re: Tran slip...
No one is giving years here so.......
Cold shifing issues, are you using non Honda Trans fluid?
Hard shifts (cold and warm)- Pre '98, check the throttle control cable from the TB to trans for proper adjustment and movement.
As always, check all mounts.
Re: Tran slip...
Dogginator
12-12-2010 10:55 AM
shewit08
18
06-21-2010 05:34 PM
