Has anyone else put a f22b1 in a 4th gen accord(90-93)?
Old Apr 2, 2005 | 05:02 PM
sonlyte's Avatar
Default Has anyone else put a f22b1 in a 4th gen accord(90-93)?
Completed swap. engine runs. havent ironed out kinks in system. IAC sensor problem (engine code).
Old Apr 3, 2005 | 03:32 PM
SearchBeforeUPost!'s Avatar
Default Re: Has anyone else put a f22b1 in a 4th gen accord(90-93)? (sonlyte)
I like cheese.
What the hell are you talking about?
Old Apr 3, 2005 | 03:36 PM
fw190bvi's Avatar
Default Re: Has anyone else put a f22b1 in a 4th gen accord(90-93)? (SearchBeforeUPost!)
yea!!!...now you have a motor with marine techonolgy, and it makes like 10 hp more w00t!
Old Apr 4, 2005 | 03:27 PM
sonlyte's Avatar
Default Re: Has anyone else put a f22b1 in a 4th gen accord(90-93)? (fw190bvi)
Its 15 hp wi zass, I didnt say I was building a drag car... not marine technology but better gas milage... If you don't know anything about it let someone who does answer. Anyone can put a f22 in. I seen that 8 years ago before they had swap kits or manuals. Checked gas prices? You probably have a car with 400 hp and sits on E.
Old Apr 4, 2005 | 03:52 PM
So do you actually have a problem with your swap or are you just e-blabbing?
Old Apr 5, 2005 | 09:48 AM
sonlyte's Avatar
The problem is with the idle at low rpm. I checked all vacuum connections. The car jerks until you get up to about 2k rpm. My top end is fine. I had to make a bracket for the throttle cable, could that cause it? Idles fine until I take off. If I don't give it alot of gas it will hesitate. My idle is at 500 rpm. I also need to know which pins on the ecu to run the secondary 02 sensor at the back of the cat.
Old Apr 5, 2005 | 12:28 PM
If you are throwing a code for the IAC, try taking it off and cleaning it gently with a toothbrush. Reset the ECU, recheck your idle. If the code returns, you will need to replace the IAC.
As far as the pin-out, try a search or check the haynes or helms manuals.
Old Apr 5, 2005 | 04:17 PM
sonlyte's Avatar
On the ECU pins -- I have a haynes manual but unfortunately it doesn't have a ecu diagram. The book I have is just really for maintenence and repair. Do you know of a manual that has a ecu diagram? Thanks for the heads up with IAC.
2pac1
Mar 26, 2019 12:06 AM
ph0on
Oct 20, 2006 09:07 PM
Blackedout97
May 22, 2006 12:06 AM
dgn1978
Jul 13, 2003 02:44 PM
prendi
20
Apr 14, 2003 01:51 PM
