SC61 Drain Question and housing Q
I was admiring my sc61 today
, and did a test fit for the oil drain (-10) and noticed that one of the housing bolts seems to be in the way a little. If you would like me to take pic let me know...it wouldn't be a problem. I also noticed that one of the bolts for the housing was loose, how do I justify how tight I should tighten it?
Thanks
, and did a test fit for the oil drain (-10) and noticed that one of the housing bolts seems to be in the way a little. If you would like me to take pic let me know...it wouldn't be a problem. I also noticed that one of the bolts for the housing was loose, how do I justify how tight I should tighten it?Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">that housing bolt is always in the way of the drain flange, you can remove it cause there is 5 more holding the housing cover on.</TD></TR></TABLE>
Can anyone else vouch for this?
ID_ten_T
Aug 30, 2004 08:41 PM
