Turbine housing problem?
Old Oct 22, 2004 | 04:53 AM
Tactic$'s Avatar
Default There's a hole in my turbo!!
I am getting closer to the install date, so needless to say, i have been inspecting the parts to make sure that everything is
I got to looking down inside the housing, and i could see a small hole (approx 1/4") right in line with a bolt that holds the housing on. It apprears that during the machining process, the manufacturer drilled the holes too deep and punched through to the inside of the housing. I can see the bottom of the bolt.
My question is, should i run the turbo? or return it ? Will it not leak?
Modified by Tactic$ at 6:31 AM 10/22/2004
Old Oct 22, 2004 | 07:25 AM
Tactic$'s Avatar
Default Re: There's a hole in my turbo!! (Tactic$)
BUMP for some help please! my install is today!!
Old Oct 22, 2004 | 07:57 AM
SilverSellout's Avatar
Are you talking about the bolts that hold the turbine housing to the center section?
Old Oct 22, 2004 | 08:10 AM
Tactic$'s Avatar
Default Re: (SilverSellout)
yes..... one has penitrated through to the inside of the actual housing. will this cause an exhuast leak out of the bolt hole. I would think that there would be nooo way that it would make its way past the threads of the bolt, but i just want to hear some opinions before i contact the seller.
thanks for helping out!
Old Oct 22, 2004 | 08:31 PM
Every turbo I've owned has had one bolt that comes through as you described. It's nothing to worry about.
Old Oct 22, 2004 | 08:47 PM
Bailhatch's Avatar
yup that's normal, won't leak
Old Oct 25, 2004 | 06:41 AM
Tactic$'s Avatar
Default Re: (Bailhatch)
thanks for the assurance guys
TateEvan
Jan 16, 2012 08:15 PM
ryguy2588
Jun 10, 2011 06:33 PM
TurboEM1
Oct 1, 2006 05:59 PM
BlueSi2k
Mar 31, 2004 01:56 PM
