gsr ecu what years can I use?
I have a '92 civic hatch si, in the car am running a '99 gsr engine. But still
running a single cam ecu, but it is chiped. Now am asking because a lot of problems have been occuring with my V-tech first code 41, and just last week code 22 which is v-tech presssure valve. Is the ecu the problem, PLEASE HELP.
if you are using a chipped p28 in your civic si then what you should use for your swap is a 1994-95 gsr p72 ecu. you will still need to wire in IAB and KNOCK SENSOR to make all the cels clear.
i have a 1995 gsr p72 for sale. good luck
what intake manifold are you running?? if stock you will want to run p72 obd1 from 94-95 but you have skunk2 or different you would want to run chipped p28 there are plenty of diff. programs you can buy according to your mods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">what intake manifold are you running?? if stock you will want to run p72 obd1 from 94-95 but you have skunk2 or different you would want to run chipped p28 there are plenty of diff. programs you can buy according to your mods</TD></TR></TABLE>
good point
good point
