Won't Go Past 7 Psi.
Old Mar 29, 2005 | 07:34 PM
S2KBAR's Avatar
Default Won't Go Past 7 Psi.
Whatup guys, I was finally done with my setup and took it to central florida turbo to get it tuned. Turns out the car won't go past 7 psi. My setup consists of a built b16 motor with a custom made manifod (no leaks), a precision turbo (SC34) .60 on the compressor side with a 57 trim wheel, and an AR of .63. Greddy type-s BOV, turbonetics evolution wastegate and a name brand manual boost controller. After that night I checked the whole system for leaks but found nothing, so I decided to go to a local turbo guru to see what was happening. He told me the boost controller was installed incorrectly and fixed it, but when I took it to the dyno again, the same thing happened. The guys as CFT know what they are doing and they still could no get the car past 7 psi. Any indicuations?
Is the turbo to big for my application? Does the spring in the wastegate (5psi with 5 shims) is too small for the boost controller to have an effect on it?
Old Mar 29, 2005 | 08:05 PM
sporkcrx's Avatar
Default Re: Won't Go Past 7 Psi. (B16 Turbo Del Sol)
How did you check for leaks in the charge piping?
Old Mar 29, 2005 | 08:10 PM
V8MeatHead's Avatar
From: Holley 4053, carb 406 stroker anal Luber, Fag
just curious what are you using as a air filter for your turbo?
Old Mar 29, 2005 | 09:26 PM
Evo-man@20psi's Avatar
Can you say boost leak ???
Old Mar 29, 2005 | 09:59 PM
Syner-G-Racing LLC's Avatar
Default Re: Won't Go Past 7 Psi. (Blue00vtecsi)
point blank...if the boost controller is not malfunctioning then boost is leaking somewhere. cause the turbo's making boost, its just not building up between the turbo and the intake manifold.
where are you getting your vacume source for the wastegate/boost controller setup?
Old Mar 29, 2005 | 10:38 PM
racinskittle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue00vtecsi &raquo;</TD></TR><TR><TD CLASS="quote">Can you say boost leak ???</TD></TR></TABLE>
WOW you're such a help.... Make sure your wastegate's not stuck open....
Does it take a long time for boost to come on?
Old Mar 29, 2005 | 11:46 PM
Tony the Tiger's Avatar
If it's boost leak, the turbo will be creating a huge sound because it is constantly trying to build boost (turbo running at full tilt).
Fit a much heavier spring in the wastegate before troubleshooting further. This would tell whether it is the wastegate at fault or something else.
Old Mar 30, 2005 | 04:03 AM
S2KBAR's Avatar
vaccum source for the wastegate is a fitting tapped at the I/C piping 5 inches from the turbine (no leaks). Boost starts to build up after 4500 rpm, I assume full bost from 5500.
I think is the wastegate because ther are not eviden leaks big enough to stop the turbo from building more pressure. Even with a vaccum line from the turbo to the upper port of the wastegate (the one used for a boost controller) it would not get past 7.
Old Mar 30, 2005 | 04:20 AM
BoostedCivicSedan's Avatar
what are these "shims" in the wastegate you speak of????
Old Mar 30, 2005 | 04:54 AM
S2KBAR's Avatar
Default Re: Won't Go Past 7 Psi. (BoostedCivicSedan)
These are small metallic discs that are used to compress the spring by a small length, therefore increasing boost. These are intalled on top of the spring
Old Mar 30, 2005 | 05:16 AM
miamidamian's Avatar
blow off may be bad and the o-ring on the greddy bov may be bad/leaking.......
on your wastegate dump does it bleed boost @ 7 psi???? maybe the wastegate is bad....( turbonetsics evo are know to do that) maybe swap it out for a tial temporarily...im sure fernando has one lying around...........
is the turbo new???? may be a cracked housing....or a blown turbo......
also how did u check the system for leaks and how mayne psi did u pressurize it to?
Old Mar 30, 2005 | 12:04 PM
sporkcrx's Avatar
Default Re: Won't Go Past 7 Psi. (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How did you check for leaks in the charge piping?</TD></TR></TABLE>
TravisBiggie
Mar 1, 2013 05:59 PM
hondamonkey
Aug 15, 2007 05:47 AM
2LiterTurboSeR
Mar 17, 2005 07:45 PM
SOHC_MShue
Jun 15, 2004 09:52 PM
18G_prelude
Apr 14, 2004 07:14 PM
