Electronic Boost Controller causing spike?
Although I don't drive a Honda, I figure that some other turbo cars may experience the same problem that I am experiencing.
My car (200sx Se-r) is equipped with a t3/t04e (.50 trim, stage III wheel) turbo with an internal wastegate. I am using an AVC-R boost controller to handle the boost.
The problem I am experiencing is that whenever the vacuum lines for the boost controller are hooked to the turbo, no matter what boost level it is at, it spikes dramatically. Example: a boost spike when set at 10 psi, goes to 15 psi. No matter the weather, hot or cold.
When the vacuum lines are unhooked, I only experience creep when it is extremely cold. I ordered the GReddy T.V.V.C manual boost controller last night hoping that it will no longer spike.
Will this be a good solution or should I upgrade to a stronger wastegate actuator? HKS sells one, and I just don't have the money to upgrade to a new manifold, external wastegate and different intercooler piping.
Thanks for any input.
Internal wastegates are known for creeping and spiking. I had pretty bad problems with mine when trying to boost over 10psi. I recently got a tial external wastegate and I no longer have any spiking or creeping problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">Internal wastegates are known for creeping and spiking. I had pretty bad problems with mine when trying to boost over 10psi. I recently got a tial external wastegate and I no longer have any spiking or creeping problems.</TD></TR></TABLE>
Right now, I'm using a BlueBird manifold, which is a factory Nissan manifold from the JDM SR20det (FWD). Unfortunately, this manifold has a different configuration from aftermarket manifolds, which mount the turbo on top of the manifold. My manifold isn't configured for external wastegate either, and I am damn broke.
I was reading on another website that HKS makes an upgraded internal wastegate that is supposedly stronger than the original wastegates the turbos come with. Can anyone verify this?
camelian
Nov 22, 2004 01:51 PM
